Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-09-2013, 12:39 PM   #1
Advice for update of old cabinets on a budget
I am trying to update our kitchen on a limited budget. I have older oak colored cabinets that have a straight line groove design running down them horizontally. Was originally planning to paint/glaze them a darker color (not quite as dark as java but along those lines - the color of the little table you see in the middle of the kitchen) but was told that probably wouldn't look good with my cabinets. Then decided to fill in the grooves but it was suggested I just leave them and paint them a light color.
THEN I discovered the pattern was not all the same on the cabinets so now I cannot leave the grooves because it would drive me crazy that they are not all the same (notice the difference in the cabinets to the left and right of the window - what the heck!).
Need advice on the best method of filling the grooves - wood filler (currently have Elmer's Wood Filler Max), bondo, or something else. What's the best method for prepping the grooves before filling.
Also, I'd like to go with the darker color on the cabinets and lighter walls (will be getting rid of wallpaper) but would it be better to go with a lighter color cabinet? (Pictures below - but be prepared - my kitchen really needs a makeover) My kitchen is rather large and has a breakfast area with a bay window that lets in plenty of light. Has anyone used the Nuvo Cabinet Paint or the Rust-Oleum Cabinet Transformation kits?
Regarding the walls, was planning on stripping the wallpaper before painting because everyone said that was best. I have begun taking off the border which hasn't been too bad. Last night I started on the wallpaper and discovered it is stuck hard and fast and they did not prep the wall with sizing before they put it up. Is it still best to take it down and repair any possible rips in the sheetrock or would it be better to paint over this wallpaper.
Last but not least, I've seen several posts regarding other older kitchens that suggest getting rid of the scalloped valance, however I have a mounted florescent light behind it and I don't have the money to redo lighting right now. Some suggested just cutting off the scallop and leaving a straight edge there. Any thoughts on that?
(And, yes, the curtains will be going too...)
Thanks!
cathjames is offline   Reply With Quote
Old 01-09-2013, 01:28 PM   #2
STAFF
BigJim's Avatar
You can replace the doors and drawer fronts and completely change the looks. You could cut the valance in a slight radius or an eye brow.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
mae-ling (01-09-2013)
Old 01-09-2013, 02:00 PM   #3
I would love to replace the cabinet fronts but I'm afraid that's not in the budget. You'll have to tell me what an "eyebrow" cut is like. I'm definitely a newbie at this.
Old 01-09-2013, 03:39 PM   #4
Wow, I've seen kitchens where the base and wall cabinet doors were different, but nothing like what you seem to have. Short of replacing all the doors, I don't see any way to update. I don't think filling the grooves is a viable option. Perhaps you could settle on a door style and replace a few at a time as budget allows. And I'd get rid of the valance altogether; it's so 1950s.
Old 01-09-2013, 05:27 PM   #5
For budget get plywood and cut your own drawer fronts and doors, then paint it all.
mae-ling is offline   Reply With Quote
Old 01-09-2013, 05:34 PM   #6
Make then into false mission style (look) https://www.google.ca/search?q=missi...w=1060&bih=741
Router more groves
Then get thin moulding say 1/8" thick by 1.25 wide. or whatever you like. Put it on the fronts around the outside mitreing the corners.
paint it all.
The Following User Says Thank You to mae-ling For This Useful Post:
zakany (01-18-2013)
Old 01-09-2013, 07:33 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
quite a few people just paint hte existing and put new drawer pulls and knobs on
woodworkbykirk is offline   Reply With Quote
Old 01-11-2013, 01:21 PM   #8
Special User
For filling grooves, I would use Bondo, not wood filler. Trick to Bondo is overfilling the grooves -- heaping it up proud, then rough sanding almost flush, then fine sanding flush. Once paint is on you'll never know it was there. Patience is definitely required though.
For painting, don't use any random latex or acrylic off the shelf. Your doors will stick closed and makes noises when you force them open (this is called "blocking" in the paint world). You want a non-blocking paint such as an oil based enamel. I also recommend using paint thinner and multiple coats, the thinner will help make the paint self-level so you don't get brush strokes.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-11-2013, 03:26 PM   #9
You keep mentioning there's no budget to do what has been suggested. Sometimes it's appropriate to just save up for a while before renovating.
Old 01-16-2013, 03:36 PM   #10
Doors arent difficult to make, and drawer fronts are super easy. All you need to do for drawer fronts is get a long 1x10, use your existing fronts to do measurements for the new ones, cut them out of the 1x10 and router the edges. If thats too thick you can cut it in half with a table saw. For doors, you can either cut them out of plywood as a slab door, using your old ones for measurements, or you can do what i did and cut out the middles from plywood and make a raised frame from 1x3's. I put four pieces of 1x3 into a square the size of door i needed, then filled in the empty middle with 1/2" plywood attached with pocket screws. theyre sturdier than any premade door ive ever seen. I put it on the cabinet and opened it all the way, then slammed it shut with all my strength and it didnt even wobble.
it will cost me $90 +Tax for nine doors. Not sure on the drawer fronts yet cuz i dont know how many drawers yet or their sizes but it wont be more than $20.
Come and see the progress on my mobile home paradise
TrailerParadise is offline   Reply With Quote
Old 01-16-2013, 05:03 PM   #11
You don't say where you are located. I know here in the Twin Cities we have a remodeling outlet store (Building Materials Outlet) that has stacks of cabinet doors. Check and see if your area has something similar.
B
Beepster is offline   Reply With Quote
Old 01-16-2013, 05:22 PM   #12
Check your local Habitat for Humanity Restore too, my local ones have tons of cabinet doors, although they arent the same
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 08:22 PM
Kitchen Cabinets - ready to assemble kind sbmfj Kitchen & Bath Remodeling 3 08-24-2012 06:02 AM
Cheap storage cabinets????? HELP!!!! Gomezy3k Kitchen & Bath Remodeling 3 06-25-2012 12:58 PM
ceiling/wall slanting over kitchen cabinets fdf Remodeling 8 02-26-2012 03:52 PM
Tiles before or after kitchen cabinets? nipab Remodeling 5 08-29-2009 10:04 AM
