Advice On Siding Issue - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 07:18 PM   #1
Rewards Points: 268
Advice on siding issue
I need some advice on a siding repair. Long story short, I need to install (or have installed) siding around 2 3rd story windows. The wife and I have been saving to completely reside the house and replace 5 windows, sadly it won't be possible for another 1.5-2 years.
Now my HO insurance says the area around the windows needs to be sided, and they have given me until august 5th to do so. They inspected the house in January when I bought it, nothing was said until just today. Sigh.
So I'm wondering...what kind of siding is this stuff? It is a 2nd layer. It seems like it has been painted already. I don't know if I should try to find some of the same siding material, or if I'll even be able to.
So, I turn to the wisdom of the board. Any help/advice would be great, time is apparently a factor, and I just want to have some general knowledge prior to calling a siding company if that's what it comes to.
It was a foreclosure, we've been gutting the interior a room at a time...I know the outside is ugly. Precious owners replaced the 3rd story windows (front and back).
Marqed97 is offline   Reply With Quote
Old 07-20-2011, 08:26 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Marq,
That looks like asbestos siding. Used to be popular years ago. I don't know if you could even buy anything like that now. Maybe someone else will chime in.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-20-2011, 08:39 PM   #3
Rewards Points: 268
That's what I feared. But oh well. Most of it's in decent shape. 3-4 spots that were damaged by cable installers, etc. I do appreciate the response very much...
Old 07-20-2011, 08:44 PM   #4
There is really nothing wrong with that siding as long as you don't disturb it. The tiles are very strong and seem to last forever. If you have some on the back of the house or garage that you could take off where they don't show and use them to fill in around the new windows. If you have to cut it, wet it while cutting so it doesn't create any airborne dust.
Mike Hawkins
Old 07-20-2011, 10:29 PM   #5
Rewards Points: 268
I've done some more reading since your first reply, and I agree...not too worried. Unfortunately there are no spares that I can use. This weekend when I'm not working I'll see what I can find around town. Thanks again for the ideas, Mike...
Old 07-21-2011, 05:02 PM   #6
kwikfishron's Avatar
Rewards Points: 618
You can buy the fiber cement version of those old asbestos shingles.
kwikfishron is online now   Reply With Quote
Old 07-21-2011, 05:09 PM   #7
Framing Contractor
Rewards Points: 120
Just thinking out loud here. What if you replaced the window with a taller one? This would only leave the siding at the sides to be replaced. Fill in the space with some Hardi panel siding, about $25 a sheet. Then install a set of vinyl shutters to hide the repair. This will buy you time until you reside. Then you would still have the new windows, and could reinstall the shutters.
sixeightten is online now   Reply With Quote
Old 07-21-2011, 07:17 PM   #8
Rewards Points: 268
The third floor windows were the newest in the house when we bought it...about 3 years old. I think the fiber/cement versions will be the way to go. I'll do some looking online and get set for the weekend. What should go under the shakes? There's some sort of semi-sticky felt/tar paper under the rest of the siding currently. Stick with that type of product? Once again, very many thanks for the replies!
Old 07-23-2011, 08:35 AM   #9
Rewards Points: 268
GAF Weatherside makes direct replacement fiber/cement siding. It's the only one I found that exactly matches what I've got. I'm going to put in an order. Our local menards apparently doesn't usually carry it...the response I got from 3 folks there was "huh?". I'll post more once I get the stuff and get up there to do it.
Hail damage roof and siding repair advice needed Ed G Building & Construction 3 06-24-2011 12:08 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
Advice on current NEC codes to clear up wire size and service issue DIYALLTHETIME Electrical 2 03-05-2009 06:24 AM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 03:56 AM
