Advice On Options With A Cast Iron Tub And Cement Board Consideration - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 05:37 PM   #1
Advice on options with a cast iron tub and cement board consideration
Hello,
I am remodelling my bathroom and had a few questions I was hoping to get some guidance on regarding my cast iron tub.
1) The wall studs next to the tub are about an inch away from the tub. Does the cement board need to be over the the rim of the tub, or can that distance be made up with caulk or something?
2) Also, its a tiny bathroom, I'd be curious about moving the tub that 1" towards the wall. Currently the floor is cement with tile laid in the cement (the floor is coming out). I am worried about moving the tub because it is so heavy, and information about this subject would be appreciated.
Any guidance would be super, thanks.
Jerrys84 is offline   Reply With Quote
Old 08-01-2012, 06:05 PM   #2
DIY staff
Rewards Points: 7,174
Pictures would help a lot---the studs need to be tight to the tub with the rock installed to the top of the tub flange---
If the tub is already installed--and there is a gap between the tub and the framing---sister in more studs--or fur out the existing studs until the wall face is in line with the tub lip---
