Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-02-2006, 06:49 PM   #1
advice on new countertops
I'm trying to find out the easiest, cheapest do-it-yourself options for a countertop. Currently mine have old formica laminate. Don't want that if I can help it. The cupboards and countertop were probably replaced in the early 60s. Built in, all out of half (at least) inch birch plywood.(That's another question I'll have shortly.) I don't think I can remove the countertops very easily (probably holds the old cupboards together), but I'd like to update. If I could remove them, I still don't think I could buy prefab, cause I'm sure the counters aren't square (and they're 27" deep), so I don't think that's an option. I'm left with tiling them. I thought maybe I could lay the concerete board right over and go from there and live with the extra inch or so in height. Or, I maybe could remove them and then put the backerboard up (if it's possible). I feel I'm left with tile. I found these 20" square porcelein tiles I like that with the 6" I could do the counter. Anyone have any ideas?
skits is offline   Reply With Quote
Old 04-20-2006, 12:03 AM   #2
When i did mine at home i fitted half inch ply over the whole of the cabinet tops then backer board and finally tiled the whole lot but on the edges front and sides i made some trim up to the size i required and finished them off.:D
lxdollarsxl is offline   Reply With Quote
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
bathroom wall advice bigbrad123 General Discussion 9 06-07-2006 08:26 AM
