Advice On Hanging Sliding Door From Ceiling Please - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 02:04 PM   #1
advice on hanging sliding door from ceiling please
i live in a concrete apartment, so no wood anywhere. i've got a 7' wide den that i want to cut off with sliding doors (similar to this) and the joist pictured below just happens to be hanging exactly where i want to hang it (running across the 7' span).
can i simply screw the door rail onto the joist? or bolt it? clamp it? the doors are heavy... maybe 100lbs.
first time i'm attempting anything like this so advice is welcome.
advice on hanging sliding door from ceiling please-2012-08-04-15-58-10.515.jpg
somuee is offline   Reply With Quote
Old 08-06-2012, 09:24 PM   #2
Rewards Points: 512
if you can reach up into the ceiling i'd rip plywood and put it in that "joist" (furring channel) between the screws and shoot some screws up in there to make the "joist" more ridgid. if not it should hold without it but more bulking up the better. then screw in your top track with longer construction screws then the screws that come with doors. mark with your level down the jamb on either side to determine where your bottom track goes. assuming that the floor is concrete screw the bottom track down using tapcon screws. hang doors on top track then lock them into the bottom track. then move the doors back and forth and adjust to level them and to make them run smoothly
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
somuee (08-07-2012)
Old 08-07-2012, 03:19 AM   #3
thanks! exactly the advice i'm looking for.
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 12:30 PM
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 11-30-2008 11:31 PM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 12:06 PM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 04:32 PM
