#1 |
HomeOwner
Advice about Waterproofing Basement Walls
Hi Guys,
I just bought a 2003 1900 sq ft ranch home. The basement is huge. This house is barely 8 years old. The basement is poured concrete. There are no cracks anywhere in the walls (They look great). I dont know how basement walls today are actually poured, but it looks like they are done in around 20-24" sections almost because there are vertical lines running every 24 inches or so (didn't measure). Anyways, I am planning to start remodeling the basement soon and was wondering if it would be worth dry-loc waterproofing the entire basement. It's probably going to cost around 500 bucks to do, so I would rather not do it if it's unnecessary. I plan to live in this house for many, many years. Should I invest and do that anyways? I live in SE Michigan. |
#2 |
Waterproofing is best done from the outside, by having gutters/downspouts that gets water at least 6' away from the walls. And grading that does the same thing. Those two things will cure 90% of basement water problems.
Poured concrete is not done in sections, it is a monolithic pour(continuous). What you are seeing are lines left by the forms. |
#3 |
HomeOwner
I do have downspouts and such to run water away, but other than a slope away from the house on the exterior brick, there's nothing else taking water away (pretty typical).
So, should I bother or not? Also, you said the lines left are from the forms. What's this process called then? I don't know what they call it when they lay the basement with this method. |
| Display Modes | |
| basement waterproofing question | c2g | Building & Construction | 24 | 02-11-2011 05:42 PM |
| Finishing basement - concrete walls options | droyer | Building & Construction | 1 | 01-13-2010 07:27 PM |
| Leaky Basement Advice | JRMN | Plumbing | 6 | 12-18-2009 06:45 PM |
| Insulating basement ceiling - your recommendations? | jtmann | HVAC | 8 | 11-24-2009 05:44 PM |
| Cement Block Basement Walls | Cactus Rose | Remodeling | 8 | 11-02-2009 12:51 PM |
