Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-01-2011, 06:28 PM   #1
Repairitplus
adobe brick and anchors
whats the best way to anchor an exposed wooden window sill into the existing adobe wall?
kirk.rote is offline   Reply With Quote
Old 09-01-2011, 06:38 PM   #2
Super Moderator
Inside the house or outside?
Old 09-01-2011, 06:41 PM   #3
Repairitplus
Inside the house. I want to install oak window sills, but Im concerned with how to anchor them down securly
Old 09-01-2011, 06:46 PM   #4
concretemasonry's Avatar
kirk -
You failed to give your location since that could help identify what the "adobe brick" is.
It could be a traditional mud brick/block or it could be a more modern "adobe stone"/"slump block" that is actually a concrete block.
Dick
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
kirk.rote (09-02-2011)
Old 09-02-2011, 07:56 AM   #5
Repairitplus
I'm still trying to figure out how to input info on "about me", but if it helps, I live in Tucson, Arizona. The structure I'm working on is probably at least 50 years old plus. I'm concerned about installing new wooden sills @ the windows, and making them secure as possible without causeing damage and more work for myself. "The adobe is traditional mud brick"
Old 09-02-2011, 11:35 AM   #6
Stuck in the 70's
Blondesense's Avatar
Originally Posted by kirk.rote View Post
I'm still trying to figure out how to input info on "about me", but if it helps, I live in Tucson, Arizona... The structure I'm working on is probably at least 50 years old plus. I'm concerned about installing new wooden sills @ the windows, and making them secure as possible without causeing damage and more work for myself. "The adobe is traditional mud brick"
Don't know about your main question, but if you go to the UserCP button on the dark bar, and follow it to "Edit your details", scroll down, then you can add your location.
The Following User Says Thank You to Blondesense For This Useful Post:
Capping a brick parapet wall jrschenck Roofing 2 08-21-2011 12:22 PM
Fasten anchors into the brick or the mortar? spaceman spif Building & Construction 12 08-02-2011 09:08 AM
Floor joist hangers for brick - 100 y/o Row House pleasantplainer Remodeling 1 07-27-2011 02:50 PM
Need your suggestions on mounting a flag bracket to brick brich General Discussion 2 05-29-2010 03:48 PM
Anchors & Brick Veneer rjordan392 Building & Construction 9 06-04-2009 05:58 AM
