Adhesive To Use On Wall Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 12:59 PM   #1
Adhesive to use on Wall Tile
I am tiling a tub/shower surround with 12" x 12" x 3/8" Porcelain tiles and would like to know the best adhesive to use for this project. Can anyone offer suggestions?
diy1stimer is offline   Reply With Quote
Old 08-13-2011, 01:07 PM   #2
DIY staff
Rewards Points: 7,174
Powdered modified thinset---do not use any premixed adhesive-"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Premixed will never dry under a big tile like that----and if it ever does it will re emulsify if and when any water reaches it through the grout.----Mike----
Bud Cline (08-13-2011)
Old 08-16-2011, 01:19 PM   #3
There's different schools of thought on this. For a tub/shower do not use an adhesive, you should use thinset.
The Schluter KERDI system is a popular way to tile bath or shower surrounds. You can get a lot of their stuff at box stores(HD), the rest you can order online or from most tile stores.
Page 10 addresses your situation:
http://www.schluter.com/media/ShowerHandbook.pdf
Schluter generally always calls for UNMODIFIED thinset, however a lot of tiling guys are also using Versabond thinset (lightly modified) with Schluter systems successfully.
Using the Kerdi membrane provides far better waterproofing/water management than just thinsetting tile to drywall or cement board.
mfc133 is offline   Reply With Quote
Old 08-17-2011, 04:55 PM   #4
Smile
Thanks guys, I appreciate the advice, I took back the pre-mix that I had purchased and went with a dry mix. It is working great so far, I am slow but it is gettting done and looks good.
The Following User Says Thank You to diy1stimer For This Useful Post:
oh'mike (08-17-2011)
Tags
tiling tub surround , tub and shower
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
replace wall tile without damaging floor tile bruswain Flooring 3 05-21-2011 06:29 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 12:01 AM
