Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-11-2013, 06:19 PM   #1
adhesive for tiles on tile redi niche
I just finished using Schluter Kerdi to waterproof my renovated shower. I used unmodified thinset and will use the same when I install the tiles.
My question is I also installed a tile redi niche. Because the niche is made of a waterproof substance I only brought the kerdi over the edges that are flush to the niche.
Can I use the same unmodified mortar to install the tiles to the premanufactured niche or should I use modified or epoxy thinset? Thanks
GBH1 is offline   Reply With Quote
Old 02-11-2013, 11:16 PM   #2
firehawkmph's Avatar
When you buy the tileready shower base, they send a two part epoxy thinset for setting the tiles to the base. Very sticky stuff, but it works. You would probably be better off getting a premade niche from a tile supply house that's made out of precast foam. You run the kerdi right into and cover the whole thing. No need for different thinset.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Tile Redi Shower pan question oc250r Kitchen & Bath Remodeling 149 02-22-2013 12:50 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
adhesive removal from vinyl tile cleaninglady Flooring 0 08-24-2012 12:21 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Newbie to 1950's house - tile adhesive removal? FixyChik General Discussion 20 01-08-2009 10:34 AM
