-   -   adhesive for tiles on tile redi niche (http://www.diychatroom.com/f15/adhesive-tiles-tile-redi-niche-171709/)
GBH1 02-11-2013 06:19 PM
I just finished using Schluter Kerdi to waterproof my renovated shower. I used unmodified thinset and will use the same when I install the tiles.
My question is I also installed a tile redi niche. Because the niche is made of a waterproof substance I only brought the kerdi over the edges that are flush to the niche.
Can I use the same unmodified mortar to install the tiles to the premanufactured niche or should I use modified or epoxy thinset? Thanks
firehawkmph 02-11-2013 11:16 PM
When you buy the tileready shower base, they send a two part epoxy thinset for setting the tiles to the base. Very sticky stuff, but it works. You would probably be better off getting a premade niche from a tile supply house that's made out of precast foam. You run the kerdi right into and cover the whole thing. No need for different thinset.
Mike Hawkins:)
