Addition - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 10:05 PM   #1
addition
I am adding on a room to an existing frame- it used to be a screened in porch. I framed around the 4x4's and left the existing wood frame at the top (aprox. 12" all around the top) and butted the drywall up to it. Is the drywall mud going to join the wood to the drywall properly, or am I going to have to slap some trim up there? Please and thank you...
shera is offline   Reply With Quote
Old 04-03-2009, 06:11 AM   #2
Not sure what you are asking. Drywall mud is for filling gaps in drywall, it is not an adhesive/glue.
Old 04-03-2009, 06:35 AM   #3
Remodeling Contractor
You will need a trim. The drywall and wood will move differently.
Old 04-03-2009, 10:27 AM   #4
trim
I am sorry I explained so poorly, what I mean to say is can I have a nice finished look without worrying about cracking etc. where the wood and mud meet. I believe Bob said that I would need to add trim which makes sense....thanks for reply and appreciate any help that I can get!!!
Old 04-03-2009, 10:52 AM   #5
Another option is to use j-Channel at the adjoining edges of the drywall. This will give the drywall a finished edge if you think a trim will not look appropriate for the design of the room. this is a channel from the drywall department not the type for siding.
Old 04-03-2009, 11:01 AM   #6
j channel
I have never heard of J channel, could you give me a brief description about it? Thanks Bob!
Old 04-03-2009, 11:24 AM   #7
It is a plastic trim that covers the edge of the sheetrock to give it a finished edge. Check out this link to see how to install it.
J-channel on drywall edge, do I glue or just put in place
Old 04-03-2009, 03:02 PM   #8
Registered User
Rewards Points: 526
Was a screened porch - now to be living space. Like apples and oranges. Foundation changes, wall changes, roof possible changes, heating and cooling, wiring, all hopefully to minimum code. Be safe, GBAR
Old 04-04-2009, 05:41 PM   #9
Drywall contractor
Rewards Points: 1,070
If the drywall is already up, J-mold (channel) won't work. It is put up first and the drywall "inserted" into the "channel". It has 3 sides. Two sides are 1/2" wide and the third 3/4" (hence the "J" reference) with the longer side fastened to the wall and the rock goes up into it. You could use "1/2 bead". It is similar to corner bead with an edge on one side that is 1/2" and one side 3/4". The narrow side slips over the edge of the drywall and the wide side (which has holes punched in it like regular corner bead) is fastened on top of the drywall and finished like regular corner bead. Trim would likely be a lot simpler and finish out fine....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-09-2009, 07:36 AM   #10
trim
I decided on the trim, thank you everyone...I'm sure I will be back with a few more...
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 01:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 10:43 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
