Adding A Viynl Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-14-2006, 09:29 PM   #1
Adding a vinyl window
Looking at adding a new construction vinyl window to my garage and can't find anything online to give suggestions to how to do this.
What would be the best way to add in a window without having to remove the T1 11 siding. Is there a way to do this?
djgregster is offline   Reply With Quote
Old 10-15-2006, 01:23 PM   #2
Can you use a remodeling window?
If you have purchased the new construction window already then you may be able to cut off the flange and install.
redline is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 09:49 PM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 11:06 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
