Adding Kitchen To Second Floor Of House - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 03:56 PM   #1
Rewards Points: 39
Adding Kitchen to second floor of house
Hello, I am looking at buying a house. I would like to split the house up into separate apts. I want to build a kitchen on the second floor. Not sure I can consult a plumber in time to have the plumbing in place before it closes.
Does anyone have any experience with adding a kitchen to a 2nd floor house? How difficult is it to have the plumbing put in place for a kitchen sink?
thanks
tiki16 is offline   Reply With Quote
Old 01-25-2014, 04:50 PM   #2
Rewards Points: 13,748
#1, I would be checking with zoning and the heath dept. to see if it's even going to be allowed.
It's not the supply's that's going to be the issue. It's the drains.
Live_Oak (01-26-2014)
Old 01-25-2014, 05:35 PM   #3
Rewards Points: 39
What sort of issues should be considered with the drain? I thought that would be the biggest problem. I am checking with by-laws. So far all I can find is info on basement apts.
Old 01-25-2014, 06:51 PM   #4
DIY staff
Rewards Points: 7,174
You really need to have a plumber look into the work---
If a sink is the only additional fixture,it might be possible to add that to the existing upstairs plumbing---or not---only an onsite review will give you the answer.
Old 01-26-2014, 11:53 AM   #5
K&B Designer
Live_Oak's Avatar
Most local municipalities have very definite zoning laws about this first of all. If the home is already properly zoned multi-family, but the building hasn't been properly converted, then it will take more than getting running water upstairs to make it a legal rental unit. You need to talk with your local codes office to determine exactly what will be required.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 01-30-2014, 09:39 AM   #6
Rewards Points: 1,456
Who would let you work on a house that you don't own and may not end up owning?
mikegp is offline   Reply With Quote
Old 01-30-2014, 03:43 PM   #7
General Contractor
Gary Evans's Avatar
There are usually stricter regulations for turning a two story house into two separate suites than for adding a basement suite.
The Plumbing is only a small part of it.
To renovate an existing home into multifamily is very expensive.......and then there's the zoning.
Gary Evans is offline   Reply With Quote
The Following User Says Thank You to Gary Evans For This Useful Post:
oh'mike (01-30-2014)
Old 01-30-2014, 07:22 PM   #8
Professional
TotalHomeworx's Avatar
The plumbing is going to be a pain but don't forget about the electrical. You will need a circuit for the fridge, circuit for the micro wave, counter receptacles, stove receptacle, etc etc
TotalHomeworx is offline   Reply With Quote
Old 01-30-2014, 07:34 PM   #9
General Contractor
Gary Evans's Avatar
Electrical, plumbing, egress, access, parking, etc, etc,
And one of the worst.......meeting fire & sound code, you need to meet fire break and sound isolation requirements for multifamily which for a standard home is not easy.
And where I am......the city will ding you another 10k - 15k ......just for the special permit and possible variances.
It's a long list
Tags
floor , kitchen , reno
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Adding a deck with roof (a porch) to a 1988 stick-built house Rector02 Roofing/Siding 7 10-24-2013 02:46 PM
Adding GFI's to the Kitchen - problems? chris_8 Electrical 13 01-12-2012 11:28 AM
Adding a bath and Kitchen in the game room cprao Remodeling 4 12-31-2009 09:43 AM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 03:17 AM
