Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-24-2009, 11:40 AM   #1
Adding door in hallway between two rooms
Morning all, me first post here =)
I found a similar post while searching, but was wondering if I could get some help specific to my situation.
I wanted to add a door in a hallway between two rooms. One of the rooms is an office and the other is a bedroom. In the winter, I like to use a little standout heater in the room, but I have to run it on high to keep the room warm. No one sleeps in the other room, so it'd be nice to have a door in between to keep the heat in, as well as a little privacy in the office/room.
How would I go about doing this? Here's a scematic:
http://img34.imageshack.us/img34/952/dooraddition.png
I'm thinking add framing wood on three sides (right, left, and top), and also I'd have to add drywall because doors are 80 inches feet tall, and not 96?
Then get an interior door in the frame from HD..
I was also thinking if it would be possible to get a 36 inch wide door and 96 inch height, and then just use 1x4s for the framing? And it's ok to use drywall screws and screw the wood framing over the drywall?
Thanks in advance.
aminus21 is offline   Reply With Quote
Old 12-24-2009, 01:21 PM   #2
Remodeling Contractor
drywall screws will work fine. But you need to fasten the studs to the studs behind the drywall in the hallway, not just to the drywall. Cheaper to use a standard pre-hung door. And only 2'6" Will look better with some wall on each side. And the extra height is special order and will cost much more than the work to drywall and paint.
redecorating a large wide 1950's bungalow hallway HOLLYROSE Interior Decorating 1 12-01-2009 01:14 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Laminating 2 rooms + hallway without transitions Arkanoid Flooring 1 08-01-2008 06:21 PM
Adding rooms under cottage billybarty Building & Construction 17 03-10-2008 10:01 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
