Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-28-2010, 10:48 AM   #1
Adding Closets
We are adding closets to two rooms that we have, before it was almost like a build it cabin but we tore that out and looking to put in some small walls then add a door.
My question is though, the floor is not exactly level, we cut out trimmers for the header and the header is not level, its about 3/8" off. We can cut one trimmer 3/8" longer, but then we may notice a gap at the floor of the door that tapers.
That being said should the header be completely level or parallel to the floor?
cbzdel is offline   Reply With Quote
Old 06-28-2010, 08:51 PM   #2
Adding Closets
Framing should be plumb and square. The door should be plumb and square. You can modify the door bottom and cut it parallel to the floor or to a saddle, that is used to give the door proper clearance.
Ron
Adding insulation and storage to Cape Cod Side Attic turin39789 General Discussion 5 11-08-2010 11:50 AM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 11:32 PM
Adding add'l support for beam WaldenL Building & Construction 3 09-01-2009 10:00 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
