-   -   Adding Closets (http://www.diychatroom.com/f15/adding-closets-74852/)
cbzdel 06-28-2010 10:48 AM
Adding Closets
We are adding closets to two rooms that we have, before it was almost like a build it cabin but we tore that out and looking to put in some small walls then add a door.
My question is though, the floor is not exactly level, we cut out trimmers for the header and the header is not level, its about 3/8" off. We can cut one trimmer 3/8" longer, but then we may notice a gap at the floor of the door that tapers.
That being said should the header be completely level or parallel to the floor?
Ron6519 06-28-2010 08:51 PM
Framing should be plumb and square. The door should be plumb and square. You can modify the door bottom and cut it parallel to the floor or to a saddle, that is used to give the door proper clearance.
Ron
