-   -   Adding a ceiling!? My whole house is concrete! (http://www.diychatroom.com/f15/adding-ceiling-my-whole-house-concrete-32789/)
flipjarg 11-28-2008 09:15 PM
My ceilings and floors are concrete and pretty much every wall on my house is cinder block. The ceilings are flat but angled and have concrete beams (probably with metal beams inside) going across the the whole length of the roof at about 4 ft apart from each other.
I want to put up some 8 ft long, 5/16 in. thick planking instead of having the concrete ceiling and also insulate between the beams. I am planning on using blow in insulation. The beams only come down about 6 in. I could use sheets of foam but that is more expensive.
My question: Does anyone have any suggestions as to how I should go about this?
My plan was to run 2x4's across the whole room using construction adhesive and concrete nails (2 1/2 in. nails don't go in far enough so I am using 2 in.) but that didn't work well because the concrete breaks up too much. The nails don't do any good.
Another thing I started doing was nailing up 4 in. pieces of the 2x4s that I could screw the full length 2x4s onto. The concrete breaks apart too much for that too.
Termite 11-28-2008 09:49 PM
Concrete nails aren't going to work for this application.
My suggestion would be to use tapcon screws to secure your 2x4's. Be sure to get at least a couple inches of penetration into the concrete. You must use the correct size of masonry drill bit for the size of screw you get, and you will need a hammer drill to drill the holes. I'd also suggest getting the hex-head tapcons and not the phillips head ones...They're easier to put and won't strip out.
Reilley 11-29-2008 08:58 AM
Err... If you get the hex heads be sure to pick up a 1/4" impact socket. I've stripped three regular chrome Craftsman sockets putting in about two dozen tapcons. The problem is the hex head isn't very deep so if the socket slips at all it just goes spinning and rounds off the head AND socket. I've yet to find an impact socket this small.
That's my rant for the day.
ponch37300 11-29-2008 11:28 AM
Reilley, are you using a 6 or 12 point socket? I've put in many tapcons and never had a problem stripping out the sockets, i've stripped a couple tapcon heads but never the socket. I always use a 6 point socket so it has more contact.
chad4290 11-29-2008 11:38 AM
depending on the ceiling maybe just build a whole new frame for new lighting insulation or whatever else you might need room for. if it is already like 8 ft. then don't use anchors like rawls because the concrete will crack. can it bear on the floor anywhere conveniently?
Termite 11-29-2008 01:07 PM
Try doing it with a phillips screwdriver! Not so easy.
A 12 point socket will strip the heads...Use a 6 point socket.
Reilley 11-29-2008 07:36 PM
Yeah I figured it would be brutal, thus why I went with the hex heads. I can't remember the last time I used a 12 point socket.
flipjarg 12-01-2008 03:07 PM
Thanks guys. I got tapcon screws (hex heads because I hate phillips head screws.) and will be getting a hammer drill from my father next time I see him. The screws came with a drill bit for pre drilling holes. I will still be using construction adhesive anyway. I'm taking no chances of this ceiling falling down on me :-).
Reilley 12-01-2008 03:12 PM
Note the size of the bit and pick up a couple spares as you will burn through a few I'm sure. Hitting a piece of rebar will dull the bit real fast. Be sure to follow the directions in that the hole should be 1/4" deeper than the tapcon will penetrate and it must penetrate at least an inch into concrete to be effective. Good luck!
flipjarg 12-02-2008 12:20 PM
I got the longest ones tapcons. They are 3 1/2 in. (i think). So the tapcons should penetrate at least 2 in. I really need to purchase my own hammer drill. I'm sure I'll need it many times after this.
Thanks again for the advice.
