Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-11-2013, 12:38 AM   #1
Adding Backsplash as a Remodel
My parents are considering adding a backsplash over the kitchen countertops. Currently, the counters have a riser that is a few inches above the surface and terminates in a 1" oak trim. My mother would like to have backsplash tile that goes from the top of the trim to the cupboards. The wall above the riser is plain old drywall with latex paint.
Can I add a backsplash tile and stick it to the painted wall with mastic?
For the outlets and switches, do I just use longer screws to acount for the extra 3/8" or so that the tile and adhesive will add to the wall or do I have to pry the boxes out and move them flush to the new surface?
For a top-notch job, should I cut out the drywall, add cement board backing, and thinset the backsplash tiles?
What would be the industry standard?
Thanks in advance.
lynxpilot is offline   Reply With Quote
Old 03-11-2013, 10:55 PM   #2
yes. thats what i did in my last home. turned out great.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
lynxpilot (03-12-2013)
Old 03-12-2013, 05:18 PM   #3
Thanks a bunch. Appreciate the response.
Old 03-12-2013, 09:07 PM   #4
Yes you can apply the tiles directly to the drywall. Use a premixed mastic. For the outlets to make them level with the tile use the plastic spacers behind the outlets. They sell them at the big box stores in the electrical aisle. Just tell them what you are doing. You will need longer screws when re installing the outlets.
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
The Following User Says Thank You to brucem609 For This Useful Post:
Old 03-13-2013, 09:22 AM   #5
Exterior Construction
Windows on Wash's Avatar
Nice work Fix.
You are developing quite the skill set!!
The Following User Says Thank You to Windows on Wash For This Useful Post:
Fix'n it (03-13-2013)
Old 03-13-2013, 09:07 PM   #6
Originally Posted by Windows on Wash View Post
Nice work Fix.
you aint seen nuthin yet. room demo for the new kitchen is starting in about 1 month. it is a bedroom now. EVERYTHING will be new. the kitchen we have now, will be the dining room. one big(ish) room.
oh'mike (03-13-2013)
refinishing a counter and adding a backsplash Lilion Kitchen & Bath Remodeling 6 08-18-2012 01:22 PM
Backsplash edge interferes with old light switch avro1 Remodeling 5 07-15-2012 08:50 AM
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 02:35 PM
removal of laminate kitchen backsplash kjeffer Building & Construction 2 08-23-2011 09:48 AM
Kitchen Countertop Backsplash Problem tarheelblue Kitchen & Bath Remodeling 7 04-29-2011 05:06 PM
