-   -   Adding Backsplash as a Remodel (http://www.diychatroom.com/f15/adding-backsplash-remodel-174144/)
lynxpilot 03-11-2013 12:38 AM
My parents are considering adding a backsplash over the kitchen countertops. Currently, the counters have a riser that is a few inches above the surface and terminates in a 1" oak trim. My mother would like to have backsplash tile that goes from the top of the trim to the cupboards. The wall above the riser is plain old drywall with latex paint.
Can I add a backsplash tile and stick it to the painted wall with mastic?
For the outlets and switches, do I just use longer screws to acount for the extra 3/8" or so that the tile and adhesive will add to the wall or do I have to pry the boxes out and move them flush to the new surface?
For a top-notch job, should I cut out the drywall, add cement board backing, and thinset the backsplash tiles?
What would be the industry standard?
Thanks in advance.
Fix'n it 03-11-2013 10:55 PM
yes. thats what i did in my last home. turned out great.
lynxpilot 03-12-2013 05:18 PM
Thanks a bunch. Appreciate the response.
brucem609 03-12-2013 09:07 PM
Yes you can apply the tiles directly to the drywall. Use a premixed mastic. For the outlets to make them level with the tile use the plastic spacers behind the outlets. They sell them at the big box stores in the electrical aisle. Just tell them what you are doing. You will need longer screws when re installing the outlets.
Sent from my iPad using DIY Forum
Windows on Wash 03-13-2013 09:22 AM
Nice work Fix.
You are developing quite the skill set!!
Fix'n it 03-13-2013 09:07 PM
Originally Posted by Windows on Wash (Post 1136177)
Nice work Fix.
you aint seen nuthin yet. room demo for the new kitchen is starting in about 1 month. it is a bedroom now. EVERYTHING will be new. the kitchen we have now, will be the dining room. one big(ish) room.
