Adding A 2nd Story Floor To Vaulted Living Room - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 06:45 AM   #16
Rewards Points: 1,274
Here's the deal-io...
Waaaaaay back in the day, pre-80's would be a rough guesstimate, nobody ever heard of trusses. Homes were stick-built and stick framed of standard dimensional lumber. Homes with walkable attics (which were eventually finished into rooms) and garages with actual space above them were common. A floor joist and a ceiling joist were one and the same.
Since the development of truss systems, and the push towards impressive, wild voloputious soaring rooflines, your ceiling and roof and the walls below that support them are no longer separate things, which one can alter. Your roof support and ceiling support, are one and the same thing. To alter ANY of it, requires that the entire space be completely redesigned and resupported. You cannot just waltz into a trussed attic space or a vaulteds ceiling space and hack out anything that gets in the way of your new plan. Your roof needs the ceiling and your ceiling needs the roof. And depending on the particular design, your roof and ceilings may be depending on a lot of other things that would suprise you.
The first step in redesigning any engineered truss space is a licensed architect. This is not DIY stuff.
LawnGuyLandSparky is offline   Reply With Quote
Raising step down living room questions phil. Building & Construction 10 02-05-2015 11:39 PM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Decorating my living room - a mess! mikailani Interior Decorating 4 10-21-2007 04:57 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
