Adding 2' Cross Tees To 4' X 2' Drop Ceiling Grid - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 11:05 PM   #1
Question
Adding 2' Cross Tees to 4' x 2' drop ceiling grid
I have a 4'x2' metal ceiling grid, and I'm changing to a 2'x2' grid. So I bought 2' Humigrid (plastic) Tee bars for each 4'x2' cell (the only choice available at the store). The Tees have molded plastic tips that hook into slots at the midpoints of the 4' lengths, and they fit perfectly. So the first row took less than a minute. The problem is the adjacent row; The plastic hook from the 1st row occupies the midpoint hole, and there isn't nearly enough room to fit two tee bar ends (one from each side) in the same hole. How is this problem typically adressed?
chaviland is offline   Reply With Quote
Old 02-12-2009, 11:54 AM   #2
Drywall contractor
Rewards Points: 1,070
Typically you find a grid that will match up from a drywall supply (most sell ceiling products) or acoustical supply. If you can't find the match cut the tab off one side of the 2' tee and just snap one side in. If your ceiling is square, the tees will stay in place when the tiles are installed......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 04:13 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 09:04 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 08:52 AM
