Added Support Under Patio Deck - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2013, 09:23 PM   #1
Added support under patio deck
My brother bought a vacation cabin and there was no diagonal supports below the deck, as you can see from the picture the deck is approx. 20 to 25' off the ground so we were concerned. The house was inspected during the purchase and the deck was considered safe. We added the redwood supports shown in the picture just to be safe and I was wondering if anyone had any comments or opinions regarding the support of the deck.
mrwoodty is offline   Reply With Quote
Old 09-30-2013, 08:04 AM   #2
Rewards Points: 13,300
I'm amazed that would have passed any inspections in your area.
What you added will help for sure.
oh'mike (09-30-2013)
Old 09-30-2013, 10:30 AM   #3
Rewards Points: 3,130
Considering where you live, I'm also amazed. I grew up not far from you (Santa Rosa) and they have codes I've sure not heard of anywhere else.
Old 09-30-2013, 11:27 AM   #4
Oso954's Avatar
Rewards Points: 772
What were the home inspectors qualifications ?
Just because he said adequate, does not mean it meets code, or that it is safe.
Your brother could start by taking that pic into the AHJ's office. See if they have any concerns. Some of them will inspect the high decks on request.
If they find problems, they will red tag it.
Otherwise, an engineer or trusted deck contractor could inspect it.
Oso954 is online now   Reply With Quote
Old 09-30-2013, 02:16 PM   #5
Just as a follow up I looked at several other decks in the area over the weekend and almost all of them seem to have inadequate bracing. I looked up several building codes for decks and followed the guidelines. We used 2" X 6" redwood diagonal bracing on all three bays and 2" X 4" horizontal bracing below and 1/2" galvanized hardware at all connections. I will try and follow up with an inspection but I think what we used seems to be sufficient.
Old 09-30-2013, 04:20 PM   #6
Rewards Points: 2,238
It's good that you braced it!
Around here - without the braces -
It would not pass!
The joints on the posts would not pass, either!
(Unless, the length of the posts are continuous.)
Also, maybe there should be bracing going toward the building!!
rossfingal is offline   Reply With Quote
Old 09-30-2013, 07:11 PM   #7
Civil Engineer
Rewards Points: 4,572
"The house was inspected during the purchase and the deck was considered safe."
I don't really understand this statement. Who considered the deck "safe"? No inspector who understands his profession would ever make a comment like that, certainly not in a written report, as inspectors are typically not trained (and are certainly not paid) to offer structural opinions on the adequacy of deck construction. Certainly not in a seismic zone like California. An inspector who offered such an opinion would be opening themselves up to enormous liability, something which they surely would not want.
Your diagonal bracing is certainly a good idea. Whether or not the deck meets code, even with the bracing, is a complicated question that can only be answered by the local code enforcement official. Note that given the height of the deck, it is taller than decks discussed in the Prescriptive Residential Guide to Deck Construction, hence is not covered by that document.
Old 09-30-2013, 09:23 PM   #8
Rewards Points: 582
the added supports will help ...but in know way would I leave it that way I agree with everyones comments..the inspector missed it big time...if it were mine... I would replace the verticial supports with properly sized material... just saying...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 09-30-2013, 10:39 PM   #9
The vertical supports are 4" x 6" what would be the proper size for these, I could not see any decks in the area that had wider than 4" x 6" supports
Old 10-01-2013, 06:12 AM   #10
We would use (at least) 6 X 6's.
"RF"
The Following User Says Thank You to rossfingal For This Useful Post:
ben's plumbing (10-01-2013)
Deck above a cement patio, footing question for the post Adamisu Building & Construction 1 05-25-2011 07:11 AM
Water Dripping from Upper Deck onto Patio JamuJoe Building & Construction 6 11-22-2010 11:51 AM
patio vs deck inChampaign, IL Painting 0 11-13-2010 12:01 PM
Attaching deck stairs to brick patio skipaola Building & Construction 2 10-19-2010 02:55 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
