Add Ceiling To 2 Story Family Room - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 10:24 PM   #1
Add ceiling to 2 story family room
Hi...1st post here...
I have a 2 story family room that I would like to add a ceiling to in order to make the room above into a bonus room. I have an attic above the 2nd floor now. I'm not sure if I need to add some columns on the 1st floor or not to help support the weight. I have attached some photos so that you can get an idea of layout of the room that I'm considering doing all of this to. Also take into consideration that my foyer is also 2 stories creating a catwalk like area upstairs... you can see this in the photos.
Thanks for the help with this...I REALLY REALLY want to get this done.
Photos:
http://s36.photobucket.com/albums/e34/jbeck22/House/
jbeck22 is offline   Reply With Quote
Old 02-02-2009, 10:37 PM   #2
You need to know the distance the floor joists would span
And what support beams/walls they can tie into
Old 02-02-2009, 10:39 PM   #3
you mean the existing floor joists right?
Old 02-02-2009, 11:17 PM   #4
No, you need to know the distance the new joists would span
Old 02-02-2009, 11:18 PM   #5
I could figure that out by measuring the opening of the family room right...the width and length.
Old 02-02-2009, 11:50 PM   #6
Yes
If the floor joists will run to that railing area then you also need to know if the beam supporting that area is sized large enough to carry the additional load. If there is a wall under the railing area you may be OK
Old 02-04-2009, 04:15 AM   #7
Rewards Points: 5,336
You need professional help with this. An architect or a structural engineer. This part of the job is not DIY.
Ron
Old 07-10-2009, 09:40 AM   #8
Have you made any progress with your addition? I am thinking of doing the same thing to my family room which is very similar to yours. I would like to see some pictures if they are available. Also, what steps did you take to get it done?
jimbuchanan is offline   Reply With Quote
Old 07-10-2009, 10:39 AM   #9
Actually if the joists are sized right it is a DIY job
Many people do this & as long as there is proper support & everything is sized right there isn't a problem
I did all the design work on my 3 story addition
I had the beams & joists sized, lumber company sent sizing info out for an engineer review & stamp - for free
I have built the entire thing myself - going ABOVE what code & sizing required
It all depends upon the abilities of the person
If I was "just" installing a floor/ceiling joists as described I would size the jopist & install
My Inspector would not require an engineer stamp
jimbuchanan - start a new thread with what you want to do if you haven't already
Old 07-19-2009, 12:07 AM   #10
I am needing some advice for a foyer enclosure, which is a similar idea but much smaller space. My foyer is about 10x8 ft. I want to enclose this to add extra room to second story. Could I use 2x10 or 2x12's and bolt them into the engineered floor trusses as the banding for the floor?
poncho is offline   Reply With Quote
Old 07-19-2009, 08:58 AM   #11
No, you can't do that. You need to speak to a structual engineer /architect to see if it's even possible to add a second story with your current set up.
Ron
Old 07-19-2009, 09:14 AM   #12
If you already have an engineered support beam/joists that beam/joists were sized to carry a specific load. As Ron said you can't add to that load unless it is reviewed with the new load added. In my area I have 2 lumber companies that will do these calcs for free. In other areas you may need an engineer to review the sizing & stamp your plans
Many Towns will not approve such a permit unless it has been reviewed & approved/stamped by an Engineer
Start a new thread with the specifics of your setup if you want further review of your setup & plans. Post pics of the area & explain the support/engineered floor trusses/sizing & where they are located
Old 07-19-2009, 09:19 AM   #13
Thanks for your reply. There are several homes in the same subdivision that have already done this same thing. I was wanting to do it myself instead of hiring it out. They all were done without any significant structural changes or problems. I just haven't done it myself and was trying to get advice on the matter.
Old 07-19-2009, 09:22 AM   #14
Thanks scuba dave. I will give a lumber company a call in the area. It's a small area and other homes in same subdivision with same set up have done this. I just didn't want to pay someone to do something I can do. Thanks for the advice.
Old 07-19-2009, 10:32 AM   #15
You do know there is more involved than the size of the joists and whether you structure can handle, right?
For example, there are codes about 2nd floor window height from the floor. But you knew that right?
You and others have been given the best advice, which is to hire an engeneer or architect to determine, if it is possible with existing structure, and what obstaqcles you will run across.
Scuba.... has built a 3 story addition, which is a long way from remodeling an actual structure. POrofessional advice at this point in the project can and will provide assurances that you are doing it right!
framer53 is offline   Reply With Quote
Tags
ceiling , family room , floor
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 04:47 PM
Skylight opening/portal through living room ceiling ControlTech Building & Construction 6 01-05-2009 08:33 PM
commercial: ceiling air vents dripping (kinda long story) cinnamongirl HVAC 5 08-03-2008 08:15 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
What type of ceiling should I use? dzimmer88 Remodeling 2 09-25-2007 04:18 PM
