Add On Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2015, 05:25 PM   #1
Add on advice
I apologize in advance if this should be under a different sub-forum:
I am attaching the my house and laundry room. When the house was originally built this area was a breezeway (under the roof) which you had to walk through to get to the laundry room. The carport has since been enclosed but I have a little problem and need ideas.
I plan to make the breezeway and laundry room into 1 large utility room but the floor in the breezeway is 5.25" lower than both the house and laundry room. The area is approx 3.5 ft. x 8ft. I want to raise the level of this to the house/current laundry room level. Better to pour a new slab (over pour) or use lumber and build up a sub floor? I will be laying ceramic tile in the room.
Fromthehip is offline   Reply With Quote
Old 06-12-2015, 05:27 PM   #2
Also, the current slab is covered in some sort of mastic. I am concerned that I could not get concrete to bond properly
Old 06-12-2015, 06:52 PM   #3
Rewards Points: 12,886
Need some pictures so we can see what your seeing.
Old 06-12-2015, 07:47 PM   #4
I'm having trouble doing that. I get an error message each time I attach the image. When my son gets home I'll have him help me.
Old 06-13-2015, 10:21 AM   #5
There will be a wall on the left. Not sure if I should do that before or after I raise the level of the floor
Old 07-01-2015, 12:52 AM   #6
Rewards Points: 338
You can tile over lumber floor. Sleepers over the breezeway slab, floor joists, subfloor, cement backer, then tile. This is if you are sure moisture will not be a problem. Otherwise, new slab may be the better choice.
carpdad is online now   Reply With Quote
Old 07-04-2015, 09:06 AM   #7
Rewards Points: 5,336
Does this breezeway have a foundation underneath that will support a structure on top?
Ron
B. Franklin 1759
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
