Acrylic Light Diffuser Cut - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 03:39 PM   #1
Acrylic light diffuser cut
How to cut acrylic light diffuser panels
RSHARPE1844 is offline   Reply With Quote
Old 05-14-2013, 04:13 PM   #2
Too Short? Cut it Again!
Your plastic shop should be willing to cut them for you if you know the directions. They might charge something nominal but usually not if you buy the plastic from them.
Depending on type and thickness you can often score the sheets with a utility knife and snap off excess at the cuts.
You can cut it on a table saw with an appropriate blade or with other saws.
Be mindful of the fumes generated. It is best to leave the protective covering on while cutting it.
Some laser cutting services will cut intricate patterns, cut-outs and shapes for you but not all will deal with all kinds of plastics because of the potentially harmful fumes generated.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Marmoleum and Nail Polish Remover AnotherDiyNovice Flooring 9 12-28-2008 03:24 AM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
