Access Panel Preventing Basement Bath Conversion? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2013, 11:00 PM   #16
Always learning...
fetzer85's Avatar
Rewards Points: 262
Honestly, I don't think anyone can give you useful advice on whether or not your new design will work until we can see what's in there.
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
oh'mike (10-02-2014)
Old 03-17-2013, 05:31 PM   #17
Rewards Points: 14
looks like a cleanout back there. it's a vertical pvc pipe with a plugged stub coming out. 1st photo is what's actually there, except the photo is upside down. not a perfectly clear shot, so 2nd photo is an example of what's there.
rook81styles is offline   Reply With Quote
Old 03-17-2013, 09:46 PM   #18
Rewards Points: 14
to keep this post short, i'll avoid too much redundant info. please read my prior statements for the full context.
In the drawing below, i've basically zoomed out from my prior drawings and deleted the finer captions surrounding the half-bath. This gives a better idea of the full basement & townhouse plumbing.
notice what appears to possibly be the main stack in the laundry room, on the opposite wall from the stack with cleanout behind the access panel. the one in the laundry room also has a cleanout on it. I'm assuming the 2 stacks are attached underground.
With the clarity on what's behind the access panel, and more info on the whole-house plumbing, anybody have thoughts on what this (specifically, the cleanout & access panel) means for renovating this basement bath? shower stall, leaving space to access panel? tub, with waterproof panel above tub? relocating the cleanout elsewhere on the wall in order to place tub/shower against that wall?
Old 03-19-2013, 12:27 PM   #19
Rewards Points: 150
Hi,
I'm not a pro, but am pretty sure cleanouts have to be accessible, with something like 3' of clearance in front of them. To use them, you have to be able to wheel a large cleanout hose on a spool up to the cleanout to send a camera or whatever equipment down the cleanout. I think it was 3' my inspector said, but don't quote me on that. This was in California.
I'm in a similar situation. I want to turn the closet which has our stack / cleanout into a bathroom. Problem is the back wall would naturally be the shower and that would seal in the cleanout, which I won't do. We also have two stacks, like you do. One by the laundry room which serves one end of the house and the other over by the wall that shoots up to the bathrooms. I presume they meet up under the concrete and go out to the street as one.
This leaves nothing but costly options of moving it or replanning to just stay clear.
Why don't you just go the other direction and take space from the storage room insteat? That seems to be very convenient...
-mike
SquishyBall is offline   Reply With Quote
Old 03-19-2013, 12:39 PM   #20
GBrackins's Avatar
Rewards Points: 2,108
not sure if this will work, but on paper it may .....
have the cleanout rotated 90 (see sketch) and extend to back wall of proposed linen closet. Cleanout would still be accessible and pipe could be hidden in the linen closet.
access panel preventing basement bath conversion?-bath0001-custom-custom-.jpg
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-19-2013, 12:55 PM   #21
Rewards Points: 150
I was going to suggest building the cleanout into a linen closet... but in that formation, you'll have a hard time opening the linen closet doors. If they go to the floor, they'll bump into the toilet. Even where they're above the toilet, it would be awkward.
So you don't want to take space from the storage room?
What about this? Turn everything sideways. Things fit better like this once you've moved the door to have toilet / sink on one side and either full bath or 1/2 shower and 1/2 linen closet on the other side. You still have a cleanout, and can build in a medicine cabinet or other storage in the space by it.
Old 03-19-2013, 10:38 PM   #22
Rewards Points: 14
thanks for the ideas. everything i'm reading says the rodding clearance for 3-6" pipe cleanout is 18" (12" for smaller than 3" pipe... 36" for larger than 6" pipe).
i can't go into the storage room because last year i built a large shelving unit into the wall... and we're already tight on storage space.
i'd also like to avoid moving the sink & toilet if possible so i don't have to mess around with that plumbing. i'm already seriously considering an above-floor drain for the shower/tub in order to avoid breaking concrete. of course, that assumes i'd be able to connect all the new pipes into the current system in the walls, which is something else i need to get more information on. if the under floor tie-in isn't far from the new drain location, maybe it's cheaper and less work than i'm imagining.
the idea of rotating the cleanout is intriguing. maybe the pipe doesn't actually have to be inside the closet, but rather just keep the existing wall the way it is, between the stack and the new closet. however, seems very difficult to locate an access panel (including trim) on a wall that's 7" wide, no?
in one of my earlier drawings, i mentioned the idea of storage in that space, and i was actually thinking of bathroom storage above the access panel, and external storage from the access panel down (not even shelves, just a little 3' cubbie space... great for hide & seek for the kids too). this wouldn't require a cleanout rotation, just 18" from the cleanout to the shower. however, good point that the toilet would make it difficult to access the storage above the access panel.
another option would be the drawing shown below. this one might make an above-floor drain more difficult, depending on how far the pipe would have to go to tie into the main system. btw, does anyone know where the underground connection between stacks is likely to be, or is it pretty much anyone's guess until you start digging or get someone in there with these pipe sensors i've read about?
any more thoughts on these ideas or other options? thanks again.
access panel preventing basement bath conversion?-basement-bathroom-opposite-wall.jpg
Old 10-02-2014, 01:44 AM   #23
Rewards Points: 14
ok, I'm dragging this thread back up. I have a new idea and would appreciate some input. Read earlier posts for background if helpful. I've added an updated drawing of my thoughts below.
In order to optimize space (ie, take as little space away from the basement rec room as possible, both in square ft and in feel), I'd really like to add a shower up against the wall that's covering the stack & cleanout. In order to keep the cleanout accessible, I'd rotate it to the right and extend it out to the new wall (will this work?) and add a panel there (access from the rec room, not inside the bathroom). I'd also move the door to the middle of the room and add a bump out for a closet opposite the sink.
Now, regarding the shower drain, it'll be within a couple feet of the stack. Can I avoid digging the slab AND avoid saniflo by just building a raised platform, trap below platform and connect directly to the stack? seems like the 1/4" per foot requirement wouldn't cost much height, if any. The ceiling is 90". How high would the platform need to be, and would it leave enough head space? I was guessing around 6", which would leave a 7' ceiling. I've heard about a running trap that could save height. Would that work?
Also, what would be my venting requirements for the shower? Could I just connect it to whatever vent(s) is already there behind the sink/toilet? i haven't opened that wall yet, but from looking inside the access panel i just know there's another 3" stack behind the toilet that goes down into the slab.
Old 10-16-2014, 04:42 PM   #24
Rewards Points: 4
How much would you say you spend monthly/yearly at Lowes and Home Depot alone?
sswood is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
whirlpool tub access panel danxp Kitchen & Bath Remodeling 0 07-27-2012 06:35 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Water Shutoff Access Panel Stuck - Need Advice Aaladc General DIY Discussions 5 06-26-2011 06:03 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 05:41 AM
