Access Panel Preventing Basement Bath Conversion? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2013, 01:50 AM   #1
Rewards Points: 14
access panel preventing basement bath conversion?
I have a half bath in my finished basement that i'm thinking about converting into a full bath. However, there's a kickout in the wall with an access panel where I'd be extending the bathroom for the shower. The attached drawing illustrates the situation, and the attached photo shows the panel. The panel is sealed shut, so before i go breaking into there to check it out, i'm wondering if anyone already knows what would be back there and if/how it might affect the extension of the bathroom. thanks.
rook81styles is offline   Reply With Quote
Old 03-14-2013, 06:06 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
plumbing drain cleanout?
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
oh'mike (10-02-2014)
Old 03-14-2013, 07:07 AM   #3
Rewards Points: 3,130
What's on the other side of the wall?
Old 03-14-2013, 07:30 AM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
Kinda looks like an access panel to tub/shower plumbing. Although it's a little high for a tub. It would make sense if there was just a shower on the other side.
fetzer85 is offline   Reply With Quote
Old 03-14-2013, 08:19 AM   #5
Rewards Points: 13,752
Remove it and find out.
Just cut the paint lines before removing.
Old 03-14-2013, 08:33 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,780
What...you don't like to peel all the paper on the sheetrock when you remove trim?
We like to see who can get the longest strand. Kind of like peeling and apple in one string.
Old 03-14-2013, 09:12 AM   #7
Rewards Points: 14
thanks for the replies. the pdf that i attached above illustrates it, but i should've posted it as a photo, so that's below. behind the wall that the panel is parallel to is the basement outside foundation. behind the wall on the left is the bathroom i'm wanting to renovate. so plumbing cleanout would make sense. if that's the case, would that have to be moved in order to put a shower there? i'm assuming it shouldn't be blocked off by the shower, but is that a possibility?
Old 03-14-2013, 09:19 AM   #8
Probably a clean out or a rough in.
Pop it open and lets see.
Old 03-14-2013, 09:22 AM   #9
GBrackins's Avatar
Rewards Points: 2,108
what is above the bath (above the panel) on the first floor?
I agree with everyone instead of guessing open the panel and see ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-14-2013, 10:38 AM   #10
Water shut offs, Studer valve, drain clean out, a pot of gold.
Old 03-14-2013, 12:18 PM   #11
Dead body...?
Old 03-14-2013, 08:46 PM   #12
Rewards Points: 258
open and take a picture.
redman88 is offline   Reply With Quote
Old 03-14-2013, 09:57 PM   #13
Rewards Points: 14
ok, i just cut through the paint at the edges inside the trim with a utility knife, and then i realized it's not a "panel" there. it's actually the wall, with a rectangle of trim attached. not sure if that's from the builder, a prior owner, or the Fannie Mae-hired contractor (they seem to have come into the foreclosure and done a quick & dirty patch & spray job all over the house).
i'm not doing this renovation immediately, so i'm not going to cut through the wall yet, but to answer some questions and provide a bit more info... above the panel on the next floor up is the corner of the living room, but just a couple feet away on the other side of a wall is the sink & dishwasher in the kitchen... and two floors up is a full bathroom. on the wall below the trim appears to be 2 golf-ball sized holes, about 20" apart, that have been patched up (poorly). not sure if that info might imply something as well.
Considering the fact that it's right next to the basement half bath and vertically close to kitchen plumbing and another bathroom, it seems likely that it's a drain cleanout. Assuming this is the case, does anyone have thoughts on what it means for the extending the bathroom the way I'm considering?
i get the idea that i shouldn't make a cleanout inaccessible. i think i'll already have to dig into the concrete to do shower plumbing, so maybe it'll be easy to have a plumber relocate the cleanout while they're at it... or just move the sink & toilet plumbing and make it all work a different way. or maybe use the ideas i've brainstormed in the below photo. any thoughts on what's possible and what might work the best (functionally, minimal time/cost, etc).
thanks again for all the replies.
access panel preventing basement bath conversion?-basement-bathroom-renovation-ideas.jpg
Old 03-14-2013, 10:01 PM   #14
Rewards Points: 14
sorry, meant to add a photo of the patched up holes below the "panel." here they are.
access panel preventing basement bath conversion?-mms_picture1.jpg   access panel preventing basement bath conversion?-mms_picture2.jpg
Old 03-14-2013, 10:20 PM   #15
GBrackins's Avatar
could be the plumbing running upstairs, closed it in with the wall to dress it up a bit
Gary
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
whirlpool tub access panel danxp Kitchen & Bath Remodeling 0 07-27-2012 06:35 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Water Shutoff Access Panel Stuck - Need Advice Aaladc General DIY Discussions 5 06-26-2011 06:03 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 05:41 AM
