About To Frame My Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 01:13 PM   #1
about to frame my basement
I have a few concerns... My basement is completely underground. I have poured concrete walls. The previous owner painted the concrete walls. I'm about to frame over them. Should I try to remove the paint?
WAINSWURLD is offline   Reply With Quote
Old 02-15-2012, 02:29 PM   #2
Rewards Points: 672
I would say no.
How are you planning on framing? There is a lot of info in the INSULATION section.
New thinking is XPS glued to walls and stick frame in front of that.
Where are you located?
B
Beepster is offline   Reply With Quote
Old 02-16-2012, 09:59 AM   #3
Rewards Points: 528
Why would you?
framer52 is offline   Reply With Quote
Old 02-16-2012, 02:23 PM   #4
About to frame my basement
The short answer is this: By painting the interior wall, you've created a "form" of water-resistance or-if you will- blockage. This superficially protects the inside from being wet but if the exterior isn't protected/waterproofed, you can still experience water damage to your walls...
I was told by a contractor (and i've heard on DIY) that concrete- just like block or brick, while solid and dense- is pourous. If you haven't waterproofed the outside walls of your foundation, water will find the path of least resistance (a pourous wall) a come thru, hence the reason for vapor barriers. Provided you have a sump pump system, you reduce the amount of water build-up and pressure around your foundation and footers. If you don't, that water sits and builds pressure until something gives way. I hope I wasn't too wordy but got the point across.
Old 02-16-2012, 03:54 PM   #5
Rewards Points: 672
That all sounds somewhat correct.
I believe the paint is already in the pores and would be hard to remove from the pores.
Make sure your drainage is spot on outside (running away from the house), do not put up any vapor barriers (let whatever seeps through breath to the inside), and READ READ READ all the posts on framing a basement that have been started in the last couple months.
B
Old 02-16-2012, 06:00 PM   #6
Thanks. I'm new to the site so still getting familiar. Will check out threads though...
Old 02-20-2012, 07:16 AM   #7
i wouldnt
I just went through what your about to do. I moved in my house a year ago. In Dec, I started the framing. I left the old paint on, 2 reasons scraping it off was a waste of time, and the repainting it would seal up the wall and trap moisture. I had no issues so I would say nope
Remod11 is offline   Reply With Quote
Old 02-21-2012, 09:10 AM   #8
Thanks. Appreciate it.
Old 02-22-2012, 12:07 AM   #9
Registered User
Rewards Points: 5,516
I'd remove as much as possible to let any moisture come through all over rather than in a concentrated area (as slab/wall joint). Foam board will allow moisture through in a controlled manner, from "worst to best": http://www.buildingscience.com/docum...study-analysis
Gary
Best way To frame basement ceiling under pipes rhk119 Remodeling 5 02-14-2012 05:22 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
estimated time to frame a basement denemante Building & Construction 4 11-01-2010 07:14 PM
Can I frame over the builders insulation in the basement? ChaoticBliss Building & Construction 35 11-09-2009 12:19 PM
