Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-24-2008, 03:05 PM   #1
4x4 Tumbled Marble Backsplash
I am about to do a backsplash to finish off my kitchen remodel. I will be using 4x4 tumbled marble tiles installed over sheetrock.
Do I need to prep the sheetrock in any way? Right now it is just painted.
Do I use thin set or mastic to adhere them to the wall?
What size groutline do I use and do I butt them right to my granite counter or leave a space then fill with caulk?
Do I need to seal them prior to grouting as to not fill all the holes and ridges with grout?
Any other tips and trick's would be appreciated!!!!
dcd22 is offline   Reply With Quote
Old 03-25-2008, 04:07 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
No, just clean off any cooking grease or construction dust
This is debated. Either is fine for this application.
This is mainly aesthetic. Tumbled says to me irregular which says to me wider grout lines. I would jay them out on a table and see what you like. I would guess that 3/16" would look good. Generally speaking connections between dissimilar materials should be caulked. I would just go ahead and grout the joint though (it may look better) if the grout cracks then just caulk it. The line between your first row of time is the same size as your grout joint.
Depends on porousity of the tiles. No sealer will keep out the grout from large pours. Generally speaking a porous tile should be sealed before grouting. Grouting can be done without getting grout on the surface if you have a really porous tile. They make a contraption that looks like a cake icing bag for just this purpose.
Brik is offline   Reply With Quote
Old 03-25-2008, 04:15 PM   #3
That's a nice post Brik
perpetual98 is offline   Reply With Quote
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 06:22 PM
marble tile in bathroom floor Arianeg Flooring 1 03-18-2008 04:07 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 01:27 PM
Backsplash advice bigboyjoel Carpentry 11 05-29-2007 09:54 AM
