40" Opening (2x) 24" Bifold Doors Too Wide 36" Too Small - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 06:10 PM   #1
Post
40" opening (2x) 24" bifold doors too wide 36" too small
I have a linen closet and I want to use bifold doors to maximize my space. But, the space opening is in that awkward range of too big for one size but too small for another size. I'm thinking of just cutting (2) 24in bifold doors to make them fit? Any suggestions???
DIY-HomeGuy is offline   Reply With Quote
Old 06-07-2012, 08:38 PM   #2
DIY staff
Rewards Points: 7,174
What choices do you have?
Special order doors---change the opening size---cut the doors ---those are the three choices as I see it--
Old 06-07-2012, 11:18 PM   #3
Post
Well, I would like to cut them but, I'm not sure how to cut them to make them fit..
Old 06-08-2012, 05:23 AM   #4
DIY staff
How much total do you have to remove from the pair of doors?
Do you have access to a table saw large enough for a door?
Old 06-08-2012, 05:33 PM   #5
Well I have 24's and I need them to be 20's so they can fit the 40in size opening...
Old 06-09-2012, 07:50 AM   #6
DIY staff
Sorry---that will fail---no way to remove 1 inch from each side and not have the doors fall apart--
Order special doors or resize the opening---
Or use slide by doors.
DIY-HomeGuy (06-09-2012)
Old 06-09-2012, 09:55 AM   #7
Rewards Points: 512
special order would be the easiest but takes the longest. you do not want to start cutting that much off of bifolds. if you need it off the honey do list so you can go fishing, golfing, etc. reframe the opening for one 36" door and go have some fun!
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
typical noob mistake: bifold doors don't fit any more threenorns Carpentry 9 01-06-2012 08:31 AM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
bifold doors elojs Windows and Doors 4 10-08-2011 10:30 PM
Replacing mirror bifold doors Mamba Windows and Doors 2 09-28-2011 12:58 AM
bifold doors loriel Carpentry 8 06-27-2011 01:21 PM
