Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-24-2012, 11:41 PM   #1
4' wide pocket door?
I've got a room that is used as a living room and guest room. The entryway to this room is 4' wide and I'd like to install a pocket door that could be closed when it's in guest room mode. It's not feasible to do 2' on each side, so it looks like it would have to be a 4' door. I've done a couple of 28" pocket door installations on our bathrooms, so i think I could manage this one.
The problem is that I don't see any 4' wide interior doors being sold. Do such doors exist? If so, where could I find one? If not, would it be possible to make one? It doesn't have to be anything fancy, since it'll be open (and therefore hidden in the pocket) 98% of the time. Finally,, it would be nice if the door is reasonably sound-proof. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 01-24-2012, 11:46 PM   #2
No such thing as a sound proof pocket door. About the best you could hope for is a soild wood 1-3/4 thick one to help deaden the sound.
Widest one I could find it 42" wide.
Your going to have open up the whole wall any way to add a header so how about just reframing to a smaller width so you do not have to order a custom door.
http://www.interiordoors.com/pocket.html
Old 01-25-2012, 02:28 AM   #3
Retired carpenter
I don't know if they even make the hardware for a 48" pocket door.
Pocket doors are real ugly anyways, not worth the trouble cutting the wall another 4 feet and installing an 8' header, when you can install French doors without any construction work.
abracaboom is offline   Reply With Quote
Old 01-25-2012, 10:05 AM   #4
Old School
Willie T's Avatar
If you have room enough to slide 48" back into one side, since you have to tear out a lot anyway for the header, can't you just slide the whole door opening over 24", and then put in two 24" pocket doors? One on each side.
Willie T
Willie T is online now   Reply With Quote
Old 01-25-2012, 10:22 AM   #5
In my area, a door in a non-loadbearing wall doesn't require a header. Just proper framing of the opening, which you likely already have since you have a hole in the wall. Have you looked into or considered True Divided lite pine interior bi-hinge doors??? you can get them with obscured glass so that privacy isn't an issue when closed. They also look nice opened fully. If you have the space on each side of the opening to open the doors, it is a considerable option.
AgBuilder is offline   Reply With Quote
Old 01-25-2012, 12:27 PM   #6
Stuck in the 70's
Blondesense's Avatar
Does it have to be inside the wall. Modified barn doors are trendy now and probably a lot easier to install.
I'm sure you could find other hardware suppliers.
~note~ Not endorsing this site, just using it as an example.
http://www.realcarriagedoors.com/har...age=sliding-hw
Old 01-25-2012, 01:12 PM   #7
crankcase's Avatar
Check out Johnson Hardware, never dealt with them just did a quick search. looks like they have different series of rail available to accept up to a 300# door.
http://jhusa.net/100pdbp.aspx
As for sound proofing or sound deadening, Im planning on building my own door but in my installation it will be hinged. Im going to rip a couple 2x4's, frame up the perimiter and add a web or 2 horizontal for support for my door knob. Then I plan on filling the "core" by laminating (2) 1/2" sheetrock and (1) 5/8" sheets. Then skin over it with 1/8" oak or hardboard. In my case I am going for the added benifit of a gypsum core for the fire door aspect.
Your going to have sound transfer either way, either thru the open doorway if its open, or the other half thru the framing wll essentially be just the 2 layers of drywall. You could however fill in the spaces between the 1/2"OSB "studs" with more 1/2" drywall pieces so as not to interfere with the pocket opening and have 1" of gypsum on each side. Does this make sense?
crankcase is offline   Reply With Quote
Old 01-25-2012, 02:33 PM   #8
JOATMON
ddawg16's Avatar
I agree with the idea of using an exterior sliding barn door. It is an option we are looking at.
Another option....Bi-fold doors?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-25-2012, 03:18 PM   #9
Thanks for all of the info and suggestions.
As for Johnson Hardware, I have used their pocket doors previously. It's very high quality stuff. In fact, I have a leftover set of rollers, and I'd just need to buy the track, which would only cost me about $100. So that's part of the reason I've been focused on a pocket door.
I hadn't thought about moving the door over and putting in a pair of 2' doors. Space is tight in this house, and that would interfere with the place where we have our desk, but we might be able to work around that. Definitely something to consider.
As for the inside barn door... I had considered that, but the hardware seems to be really expensive compared to pocket doors. It also seems to me that any reasonable sound-proofing would be far more difficult, if not impossible.
I guess the bottom line is that I'm undecided, but still leaning towards a 4' door, if only I could find such a thing. I had considered building one, and I might think about the feasibility of that a bit more.
Old 01-25-2012, 03:58 PM   #10
have you looked at these?
http://www.inventiveusa.com/home.html
Old 01-25-2012, 10:06 PM   #11
Msradell's Avatar
Very interesting concept, have you ever used one?
Msradell is online now   Reply With Quote
Old 01-25-2012, 11:43 PM   #12
http://johnsonhardware.com/111pd.htm
You can use hardware like this and a single 4' door or 2 2' doors that both slide the same way, could even connect the two doors together so slide as one.
mae-ling is offline   Reply With Quote
Old 01-26-2012, 11:41 PM   #13
bpm
Are you doing a pocket door because you want to save the space of standard door swinging in or out of the room? If that's not an issue, you could close the existing opening down a bit and just install a standard door. It would likely be a lot easier and wouldn't require you to open up the wall to do the framing for a pocket door.
bpm is offline   Reply With Quote
Old 01-27-2012, 12:47 AM   #14
Now that's a thought. It would be pretty easy to connect a pair of 2' wide doors together and have them pull as one. That might be just what the doctor ordered.
Old 01-27-2012, 12:52 AM   #15
It's a space issue. We already have pocket doors on both of the bathrooms for the same reason. In addition to this 4' entryway that currently under consideration, there's one more spot where I'll eventually put another pocket door (or maybe a barn door for that one). They make a big difference in tight spaces.
Split pocket door Justin8152000 Building & Construction 6 06-20-2011 04:53 PM
New Door Slightly Too Wide Wino General Discussion 12 12-29-2009 11:57 AM
Entry Door Size han Building & Construction 5 08-20-2009 08:54 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
