30" Spaced Rafters In Old House - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-11-2014, 10:08 AM   #1
Question
30" spaced rafters in old house
Hello,
I have taken out the ceiling in the kitchen I am vaulting the ceiling in an old house. The roof already sags, I have put in 4 sky lights. The rafters are 30" on center 2 x 6 spanning about 15' from wall to peak. There are no collar ties. I am not trying to make the roof flat but for structural purposes should I add rafters and or collar ties for support? I live in Cleveland and well...we get heavy snow at times. Thank you for any help.
dczuchra is offline   Reply With Quote
Old 07-11-2014, 11:35 AM   #2
DIY staff
Rewards Points: 7,174
Yikes. Post a picture or tell us more. Without ceiling joists the walls could bow out and cause the roof to collapse.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
dczuchra (07-11-2014), GBrackins (07-11-2014)
Old 07-11-2014, 01:07 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
YIKES IS RIGHT MIKE!
may want to take a read of this article from Fine Home Building .....
http://www.finehomebuilding.com/how-...l-ceiling.aspx
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
dczuchra (07-11-2014), oh'mike (07-13-2014)
Old 07-11-2014, 01:15 PM   #4
Thank you for the reply. Yikes was my thought as well. A friend of mine is actually doing this and I will get photos posted this evening. Thanks again.
Old 07-11-2014, 03:48 PM   #5
Civil Engineer
Rewards Points: 4,698
A friend of yours is doing this to YOUR house? You should probably have a discussion immediately with your friend as to their level of understanding of framing and structural support. For your information, collar ties are used to equalize uplift pressure on the opposite sides of the roof during high winds. Collar ties are not intended to resist outward thrust of rafters. To resist outward thrust, you need floor joists or you need to install a ridge beam and connect the rafters using special brackets. In any case, converting a structure from rafters with floor joists to a cathedral ceiling requires careful design, and structural modifications to the building.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 07-11-2014, 04:08 PM   #6
To Dan, Thanks for the post. This is a long story, but in short a friend buys and sells houses....had a great contractor doing the rehabs for them, they had a falling out and he now thinks he can manage on his own and save money. I walked in there and my eyes blew up (I built homes with my Dad growing up). The reason I posted was that he said he had an architect draw up plans and make changes that needed to be made after the house was gutted and re-configured (stairway was changed, went from a 3 to a 2 bedroom, added a bath, vaulted the ceiling etc etc.). Architect made no mention of having to correct the structure of the ceiling in his plans submitted to the city. I appreciate the input and please stay tuned for the pictures...could be entertaining!
Old 07-11-2014, 04:14 PM   #7
roofermann's Avatar
Rewards Points: 401
"Could be entertaining" is an understatement. with 30" oc rafters, what did they use for sheathing? 5/4 oak might be strong enough, anyway, good luck and looking forward to updates.
roofermann is offline   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
Tags
collar ties , rafter , roof support , sagging roof
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 10:58 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
New custom house, concerns/problems. pretzels Building & Construction 15 04-16-2011 01:17 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
