3 Way Wiring - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-14-2007, 02:52 PM   #1
3 way wiring
I recently read an article on how to wire 3/way using only 12/2/wg..i did not save, and i can't remember the site...it is using in high volume, such as apartment complexes, or condos, where cost of copper is of major concern. can you help?
Tony Cunningham is offline   Reply With Quote
Old 08-14-2007, 07:32 PM   #2
Agent 000
SecretSquirrel's Avatar
This post should be in the Electrical forum to receive the appropriate attention.
The only situation that I know of where you can run 2 conductors is for the travelers between switches. You still have to feed one switch hot and the other switch would provide the conductor going to the light. The light would still need a neutral and a ground. I don't see any savings one way or the other unless the switches were a long distance from one another.
SecretSquirrel is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
