Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-21-2010, 01:58 PM   #1
3 Season Porch Remodel
I bought a home about a year ago that has a three season porch that could use some upgrading. Currently it has a textured looking wallpaper covering the ceiling and outer walls and exterior vinyl siding covering the interior walls. The ceiling is 8' on the interior side and slopes down to about 6' on the exterior side. I am trying to figure out where to start and how to keep this fairly inexpensive. I do not want to do drywall as the porch is not heated and with the temperature swings in Colorado it may not hold up. Any thoughts? I'm definitely open to suggestions Jason
Biyobe is offline   Reply With Quote
Old 03-29-2010, 11:46 PM   #2
water flows downhill
oarfish's Avatar
Painting could be on option.
Do you have pictures?
oarfish is offline   Reply With Quote
Old 04-02-2010, 06:10 PM   #3
Drywall contractor
Wood would be my choice. Drywall is not a good product where great temperature/humidity swings occur. Look at any number of unheated/uncooled garages over a few years old and you will likely see tape coming loose in several areas, corner beads popped loose, etc.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-02-2010, 10:43 PM   #4
I will try to get some uploaded soon. The space is small so hopefully once I figure something out it will be a easy project. My parents also have a 3-season patio and they have some type of metal ceiling. My dad thinks it is called beadboard?? But I can only find that in a wood paneling type material. I'll post photos soon. Jason
Old 04-03-2010, 09:49 AM   #5
Drywall contractor
A tin ceiling is another option. Google "tin ceilings / DoItYourself.com".
Old 04-03-2010, 10:46 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can use soffit board (rated for exterior applications):
http://www.certainteed.com/products/...-boards/309426
http://www.americangypsum.com/products/detail/?p_id=141
http://www.nationalgypsum.com/submit...29%2000-05.pdf
- Build Well -
Old 04-10-2010, 12:35 PM   #7
Here are the photos of the walls/ceiling/floor. Any suggestions are welcomed I looked up the tin ceilings and they all seem a little bit too much of a "fancy" look to them. I'm thinking wood might be the best bet all around? Jason
3 Season Porch Remodel-photo-1-.jpg   3 Season Porch Remodel-photo-2-.jpg   3 Season Porch Remodel-photo-3-.jpg   3 Season Porch Remodel-photo-5-.jpg   3 Season Porch Remodel-photo-6-.jpg
Old 04-10-2010, 04:57 PM   #8
Drywall contractor
Beadboard would look nice. I'd use the planks, not the 4'x8' sheets. Costs a little more, but looks nicer and will hold up better.
Old 04-10-2010, 08:27 PM   #9
i like the floor
The older I get the better I was
How do I renovate my 3 season porch? glamgirrl Remodeling 4 03-09-2010 08:34 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
How to rebuild a porch with a roof? redblotoflife Carpentry 2 11-23-2009 05:35 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
Pollen season and my new yellow porch dchaban Building & Construction 9 04-25-2008 01:18 PM
