2x4 Size Difference - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 09:53 PM   #1
Rewards Points: 87
2x4 size difference
I am framing my basement. I bought some 2x4s and I also kept some 2x4s from the old finished basement. I just found the actual width of the them are different. There are about 3 different measurements. The differences are about 1/8 to 1/16. Should I avoid mixing them?
diy001 is offline   Reply With Quote
Old 07-14-2013, 06:18 AM   #2
DIY staff
Rewards Points: 7,174
Yes---save the odd ball ones for blocking or other uses---you will have trouble with drywall finishing if the studs are mismatched.
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 11:20 AM
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 01:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
