2x12 Beam Vs Glulam - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 08:36 PM   #1
Rewards Points: 330
2x12 beam vs glulam
I have stripped a house down to the studs and now
I want to knock out 10' of an interior load bearing wall.
single storey ranch style,2x6 joist and rafters 24" OC
What are some guidlines for beams/
kt82 is offline   Reply With Quote
Old 01-27-2009, 11:05 PM   #2
You need to know your building width and the distance you are spanning. Call your local lumberyard with those numbers and they will size one for you according to the manufacturers specs. It can get tricky because there are snow loads, wind loads, seismic conditions, codes, etc. If there are any special conditions too, you need to take them into consideration as well. You might need an engineer or architect.
You just don't guess what you need. Something you guess on might look good initially but in the middle of the winter when you have 4 feet of snow on the roof it might fail. Or you could go overboard and put something in that's way overkill and spend extra green that you don't have to and end up performing extra work to accomodate your overkill.
As long as you don't have any special conditions your local lumberyard will be able to look it up and tell you what will work.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-28-2009, 07:12 AM   #3
What he said, have an expert do the calculations. But for a given size beam, glulam is stronger that stick built beam.
Old 01-28-2009, 09:57 AM   #4
Rewards Points: 330
all right. The glu lam is 40 bucks more so I will use it .It should impress the BI. Thanks
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
building a glulam beam miller4000 Carpentry 2 03-29-2007 04:14 AM
