2nd Story Porch In Florida Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-01-2008, 02:10 PM   #1
2nd story porch in florida question
I have a 2nd story wood porch, Need to tear up and replace.
I was thinking of using 3/4 t&g plywood untreated or 3/4 treated plywood.
Flashing on the sides and peal and seal on top of the wood with outdoor carpet.
Do any of you have any suggestions
Thanks in advanced
cflman is offline   Reply With Quote
Old 08-01-2008, 09:22 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
is this porch above any living quarters? if so remove the plywood with the first 16" of siding around the porch walls. install new plywood T&G and install a good 1 piece rubber torch down or glue down roofing membrane over the plywood and up the walls aleast 12" then reinstall the siding. BOB
Old 08-02-2008, 09:39 PM   #3
Its a wood deck it buts up to stucco over wood on the walls. If i replace the decking and do a felt lap? can i paint it with a elastomeric paint? i would like to have it as a white deck. Thanks
Question about temperature of a florida room randalg General DIY Discussions 1 04-08-2008 11:38 PM
Question: second story addition to existing room elmorem@gmail.com Building & Construction 3 02-17-2008 09:38 PM
New construction porch question bayoudonnie Carpentry 3 09-23-2006 02:11 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
