Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-12-2013, 02:26 PM   #1
24" Raised Panel Door Re-Hang
Hello,
I am trying to rehang a turn of the 20th century raised panel door. Unfortunatly the previous owner had removed the door and removed all the jams and put in its place a 1x6. The rough door opening after removing the 1x6 is 27 1/2 inches wide and 72 inches tall. The door measures 24 x 71. My question is what should the door opening measure in width after the new jam is installed. Thanks in advance for your help.
fullbugg is offline   Reply With Quote
Old 01-12-2013, 03:50 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
the door jamb itself should be 24 1/4 wide as to allow the door to properly open and close.. if your using raw wood thats unprimed yet make the header 24 5/16, this will allow for the thickness of 1 coat of primer and 2 coats of paint
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
fullbugg (01-12-2013)
Old 01-12-2013, 03:54 PM   #3
funfool's Avatar
sounds about right. If you went and purchased a pre hung door at 24", you would want your rough opening 3" wider for the new jambs, or 27"
The actual door would measure 23 3/4" wide.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
Tags
rough door opening
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
