19" Spaced Joists - Foil Faced Insulation? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 09:08 PM   #1
Question
19" spaced joists - foil faced insulation?
The joists between my upstairs and downstrairs bathrooms are an unusual size (19" apart and 10" deep) and were previously insulated with foil faced insulation (see attached image). I had to pull the old insulation (mold resulting from a leak upstairs), and am a bit puzzled what to replace it with.
I haven't seen any foil faced insulation at my Lowes or Home Depot, and rolls of kraft faced insulation are only 15" wide, not 19".
So my questions are:
  • First question: Do I really want foil faced (or vapor barrier) in the space between upstairs and downstrairs bathroom?
    • Possibly because the downstairs bathroom is a tiny room w/a heating vent and upstairs does not have one, so if I leave the doors shut in the winter the top bathroom gets rather cold and the bottom gets rather warm?
    • Possibly because the wall on the right is exterior?
    • Possibly because there is plumbing for the upstairs bathroom in the ceiling between the joists?
  • Second question: how do I insulate the 19" space? Can I order 19" rolls somewhere (or larger and cut them down?)
Thanks in advance!
CWorth is offline   Reply With Quote
Old 03-13-2009, 05:36 AM   #2
Remodeling Contractor
vapor barrier between to conditioned spaces is not necessary. You buy 24" wide insulation and cut it down and use insulation ties to hold it up. These are flexible metal rods that are pushed up to hold the insulation by gripping into the joist edges
Old 03-21-2009, 12:26 PM   #3
Thanks, Bob.
Old 03-21-2009, 12:26 PM   #4
Thanks, Bob. Just the information I was looking for.
Tags
bathroom , foil , insulation , joist
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 07:23 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 01:23 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
faced or unfaced insulation wiggs Building & Construction 5 04-19-2006 05:50 AM
