$1300 Difference In Drywall Quotes?! - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-20-2007, 09:45 AM   #1
$1300 difference in drywall quotes?!
The previous owners of our house did a skip/trowel job from hell in the den. The rest of the house has a knock down finish which I like.
The room is about 15 x 20. The ceilings crown at the top about 11 ft from the floor. I received two quotes to float and re-texture the walls and ceiling. I told them I'd have the room cleared and sealed from the rest of the house. No painting either. I'll paint it myself afterwards.
Quote #1 was $1900. Quote $2 was $650. Both are drywall companies. Does this range seem typical or is #1 way out of bounds? What would you expect to pay for this job?
Jeff
Jemo is offline   Reply With Quote
Old 04-20-2007, 10:51 AM   #2
I will request pictures / references from the $650 guy and go from there... as it is way too much difference in pricing, going with the most expensive quote here seems not reasonable...
KUIPORNG is offline   Reply With Quote
Old 04-20-2007, 01:51 PM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
Maybe get quote #3 and see where it lands?
J187 is offline   Reply With Quote
Old 04-20-2007, 03:18 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,290
The $1900 sounds like a "I don't want to do it but I'll do it for $1900" price. It sounds like he's saying go away.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-20-2007, 04:03 PM   #5
J187's Avatar
Rewards Points: 506
Whoa - I just went back and reread that you said ONE room. I actually didn't pick that up originally - that'll teach me to scan through. I'm not sure from any experience what the cost should be, but my intuition tells me that's insanely high.
Old 04-20-2007, 06:51 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Jeff
Hi Jeff,
FWIW-We do these kinds of jobs all the time.
IMHO:
$650.00 - I wouldn't trust it coming out too good.
$1900.00 is WAY too high.
$800-$1200.00 should be the right range dependant on the actual room (which we cannot see)
- Build Well -
Old 04-20-2007, 07:56 PM   #7
J187's Avatar
Rewards Points: 506
Ask each company for references and also run a quick check online. Maybe check the better business bureau too. I have complained to the BBB before and it does make people think.
Actually, ClutchCargo - you know Auto Services of Medford? ON Mystic? I wrote to the BBB about them. They broke into my Wife's car at her apartment because the landlord wanted to move her car while she was out to bring in a moving truck. The landlord asked auto services if they could gentle tow it out and put it back w/ out entering it. THey said yes, came, pried the door open w/ a bar, broke her shift lock release and backed it out in neutral. The car took in water after that they bent her door so badly!
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
