1/4 Or 1/2 Backerboard - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 02-24-2008, 11:25 AM   #1
1/4 or 1/2 backerboard
feeling stupidier every day ha.i have 3/8 sheet rock in my hose.im redoing bathroom shower.i framed ,shimmed around shower pan so that everything would be flush on surrounding wall for 1/4 inch backerboard.now i found out you cant use that on walls.what could happen if i used 1/4 inch backerboard and do you think it would be ok to use it on one wall only that joins into existing 3/8 sheetrock and 1/2 inch on the rest.were wanting 3/8 tile.should i start over.thanks
GLASSMAN1 is offline   Reply With Quote
Old 02-24-2008, 11:29 AM   #2
Backerboard is important for tiling a shower. Moisture-resistance, strength, tile weight, thinset adhesion, etc. But, if you have a pre-fabricated self-sealing shower enclosure, it can be affixed directly onto the studs with no actual drywall, backerboard, etc. as per the manufacturers' okey-dokey.
End Grain is offline   Reply With Quote
Old 02-24-2008, 11:33 AM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
First off installing tiles over sheet rock especially in a moisture rich environment such as a shower is probably one of the biggest no-no's ever. The tiles will peel off. The framing for the shower should be the same size as the pan (Assuming it is a fiberglass pan) then you install Durock (cementiciouse board) so it comes down over the lip keeping it about 1/2" off the pan so as not to let the Durock be immersed in water if it should leak. Tile walls allowing tile to come down to pan. You really have no way to fasten anything 1/4" and expect it to stay more than a few years.
USP45 is offline   Reply With Quote
Old 02-24-2008, 11:38 AM   #4
GLASSMAN1, I misunderstood your reference to backerboard as cement board is commonly called that - perhaps erroneously - out here in AZ. Mea culpa. USP45 is 100% correct in the recommendation for the actual material you should ask for and use. And, his reasons are right on the money. Moisture-resistant drywall is called greensheet or greenboard out here.
Old 02-24-2008, 12:01 PM   #5
i have framed the studs so that they are flush with the inside lip of shower pan,also i have put studs were im going to screw the shower door to.the sheetrock is only on one side and its way above were any water is going to hit.the rest is being redone all the way to the ceiling.have you heard of anybody useing 1/4 inch backerboard around showers and was it strong enough to hold the tile?
Old 02-24-2008, 12:23 PM   #6
1/4" will not be strong enough for wall tile. You'll need to use 1/2". What kind of backerboard are you going to use?
jerryh3 is offline   Reply With Quote
Old 02-24-2008, 02:51 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use 1/2" Cement board in your shower wall area.
Tear the shims out. That way, the difference will only be 1/8".
Make that up, by having the tile sit over the cement board just slightly, (where it meets the 3/8 S/R). Grout the 1/8" gap.
- Build Well -
Old 02-24-2008, 04:20 PM   #8
im useing hardi backer board.thanks for information.i geuss we learn as we go .
Old 08-11-2014, 11:58 AM   #9
1/2" hardie isn't 1/2"
Here's the deal. 1/2" hardie backer isn't really 1/2". It is 7/16". The reason they make it 7/16" is so that the thin layer of mortar holding the tiles will be hidden by the drywall edge that butts up against it. In your case, the difference will be only 1/16" and is easily groutable, or you can just silicone that edge for an even better seal as grout is semi-permeable to water (not that it really matters on a vertical edge).
I don't see why you can't put 1/4" hardie on the wall, then screws (counter-sunk well!), then a thin layer of mortar for bonding, another sheet of 1/4", and more screws. Be advised though, that 1/4" hardie is actually slightly more than 1/4". I believe this is because tumbled edges of tile shouldn't sink below an adjoining surface edge so it's slightly more than 1/4"... if that makes sense.
Also, when you silicon, use painter's tape and mineral spirits to get a nice caulk line.
My two cents, cheers!
Galileo007 is offline   Reply With Quote
Old 08-11-2014, 10:41 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is going to be "one-screwed-up-shower" my friend. What a train wreck this is going to be!
XXX
Old 08-11-2014, 11:22 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just noticed this thread is six years old. Suckered again!
Galileo007 pat attention will ya!!!
Fixif likes this.
XXX
Old 08-12-2014, 12:45 AM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
For the record....Hardibacker says you 'can' use 1/4" board for showers. But I think everyone agrees 1/2" is better.
My downstairs shower has 1/4" hardibacker....but I also have my studs a lot closer than 16" OC. No issues. Nice and straight.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
carpdad (08-12-2014)
Old 08-12-2014, 10:06 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
FOR THE RECORD...
Show me a link to that information please, so I can read it for myself. I know of no 1/4" tile backer suitable for wall use. Let's get to the bottom of this before someone suffers damages from some dubious information. If I am in error I will be happy to stand-corrected.
XXX
Old 08-13-2014, 12:44 AM   #14
JOATMON
ddawg16's Avatar
Originally Posted by Bud Cline View Post
FOR THE RECORD...
For the record.
http://www.jameshardie.com/homeowner...iebacker.shtml
Yes, HardieBacker 1/4'' cement board may be used in a shower. However, we recommend HardieBacker 500 if you need to make a smooth transition to drywall. The board must be mechanically fastened every 8'' on center to the wood or metal studs spaced a maximum of 16'' on center. A vapor barrier is needed if required by local building codes.
Old 08-13-2014, 01:55 PM   #15
LOL... There is nothing wrong with being right 6 years later. I found the thread while researching an install and so will someone else 6 years from now.
staggering backerboard GLASSMAN1 General DIY Discussions 5 02-24-2008 04:44 PM
Backerboard installation CD08 Flooring 2 10-23-2007 01:18 PM
Installing Backerboard for Ceramic Tile Floor average Flooring 4 09-25-2007 12:06 AM
backerboard glassman General DIY Discussions 1 02-11-2007 10:33 AM
What Comes First-Drywall or Backerboard?? allen1466 Remodeling 15 04-01-2006 10:57 AM
