Would This Be Ok ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 09:44 AM   #1
Rewards Points: 240
would this be ok ?
i have my floor torn up, down to the planks that are on the floor joists.
the plants are sqeeky. i have been using screws to fasten them down = kind of a pita. i was thinking that i could use my framing nailer to fasten the planks down. i would only do it around the parameter where furniture would be = not a walked on area. walking areas would still be screwed.
would this be a lasting fix ? it sure would make things go faster/easier.
Fix'n it is offline   Reply With Quote
Old 11-17-2012, 09:45 AM   #2
Rewards Points: 240
oh. i am putting 1/2 sheathing over the planks. then whatever laminate i decide, down the road.
Old 11-17-2012, 09:54 AM   #3
Rewards Points: 14,312
What are you using to fasten the screws? An impact drill would be the tool of choice.
If your going to nail it make sure to use 2-1/2" ring shank nails.
Sure hope you not trying to use sheetrock screws.
Really need to be adding screws to every single plank not just the outside.
What happens when you install the underlayment and it still squecks?
Sure hope your using underlament rated 1/2" and not something like CDX.
Anything less will have voids in the plys.
Old 11-17-2012, 10:24 AM   #4
Rewards Points: 6,652
I used deck screws that have te sqaure head, when I did our bath floor, before putting down the underlay and tile.
No squeeks. Just place the screws next to where the nails are.
Old 11-17-2012, 01:18 PM   #5
That's what I use to, mainly because I own a stand up screw gun that uses them.
Old 11-17-2012, 06:14 PM   #6
Rewards Points: 240
well, you not going to like this. but, it is working just fine.
a regular drill = i don't have to worry about the batteries in my impact drill.
i gave up on the nailing = i don't have any long enough ring shank nails.
cough, umm, cough. uh yeah. i have a bunch of 2" drywall screws. and they work just fine. except for the occasional HARD board, the heads break off. otherwise they working just fine.
yeah, i am using 2 screws per plank. funny (not) thing i am finding, is that a lot of the original nails were put in so close to the edge of the joist, idk how they even stayed in.
i have the sheathing just laying in place (no screws yet). and this floor is pretty darned quiet and solid.
i am using 1/2 sheathing rated osb, 1/8" gap that i will caulk. . i have 2 bedrooms done this way. and the results are good.
now, if you want to tell me what is going to happen because i did it this way, thats fine. but, it is what it is, and i ain't changin it. and i am very happy with the results.
Old 11-17-2012, 06:47 PM   #7
DIY staff
Rewards Points: 7,174
You will be fine---the drywall screws were a poor choice because they can snap---the gold one would have been a better fastener---however--it's done and I doubt if you will ever head from the squeaky nails again---
Old 11-17-2012, 06:55 PM   #8
Rewards Points: 240
. i was thinking that them breaking was the issue, or perhaps rusting.
otherwise i couldn't think of a reason to not use them. like i said, there are a few planks that are very hard and the screws snapped. otherwise the screws set just as they should.
Old 11-17-2012, 07:04 PM   #9
DIY staff
In the future use the gold ones---drywall screws are hardened and ,under stress like shifting wood--the heads can pop off or the shafts snap---
When buying supplies to keep on hand----get the gold ones---they are a few cents higher than the black---but are more versatile---
Just a note---square drive are great for floors and decks---the heads don't strip out like Phillips do---
Fix'n it (11-18-2012)
Old 11-18-2012, 07:58 AM   #10
Rewards Points: 240
will do ......
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (11-18-2012)
Old 11-18-2012, 10:31 AM   #11
Home Remodeler
Rewards Points: 164
I would install roofing felt over the sub then the OSB. Just saying.
mikey48 is offline   Reply With Quote
Old 11-18-2012, 10:52 AM   #12
Rewards Points: 240
why is that, what does it do ?
Old 11-18-2012, 11:00 AM   #13
Moisture barrier, along with helps to quiet the flooring.
Old 11-18-2012, 11:49 AM   #14
Rewards Points: 240
i don't think i need a MB as there is a basement . and it is pretty dry down there.
Old 11-18-2012, 12:12 PM   #15
You would still need the felt, regardless. In the long run you will thank us for the suggestion.
