Working With Twisted PT Lumber - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 11:42 AM   #1
Rewards Points: 1,010
Working with twisted PT lumber
I am preparing to place a couple of pieces of 2"x10" pressure-treated pieces of wood along my deck as a skirt. Two problems. The first is where the two pieces meet is at an odd angle. That's normally not a big deal, but the second problem is the pieces of wood I have are rather twisted after I let them sit outside for a bit to weather.
So normally with two nice, straight pieces of wood I could "dry fit" them to the side of the deck, mark the angles where they cross, and then take them down to easily cut with a miter saw. The only way to do it now is I have to clamp them uber-tight to the deck, mark my lines, and then cut them while they are still clamped tight to the deck.
Any suggestions on a cleaner way to do this? Or should I bite the bullet and go buy new, flat pieces of lumber? I'd rather save the money and use it on more useful things. Like lottery tickets.
spaceman spif is offline   Reply With Quote
Old 04-30-2010, 12:18 PM   #2
kwikfishron's Avatar
Rewards Points: 576
You just learned something about “weathering” treated lumber.
Hopefully you can find something else to do with those boards. Maybe in the garden or something.
kwikfishron is online now   Reply With Quote
Old 04-30-2010, 05:44 PM   #3
Framing Contractor
Once it's twisted like that you're done. It will get worse if try to clamp/cut and nail. You have to buy new.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-30-2010, 10:07 PM   #4
Rewards Points: 1,910
Whenever I need to use PT lumber I buy it the day I'm going to use it. Then I speed home without stopping at stop lights and nail it in fast before it springs into a pretzel. Ok, I'm exaggerating a little. But it does twist fast as it dries.
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 05:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 10:44 PM
