Workbench Top ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 01:55 PM   #1
Rewards Points: 205
Workbench Top ?
I'm building a tabletop for a workbench and need recommendations on the top material. This will not be a heavy-duty garage type bench. This will be used for smaller, craft-type projects, constructing RC aircraft, maybe even thread-injecting. Looking for the most affordable options. It is 36" x 82" so a 4x8 sheet of whatever will work.
Thanks.
CosmicMiami is offline   Reply With Quote
Old 05-23-2013, 02:24 PM   #2
Rewards Points: 2,630
I have 3/4" plywood on mine, over top of 2 x 6 frame. The other material you may want to look at is MDF. MDF does not like getting wet, but otherwise is very flat and smooth -- looks nice.
SPS-1 is online now   Reply With Quote
Old 05-23-2013, 02:34 PM   #3
Rewards Points: 24
20 years ago or so, I built a "temporary" combination desk and hobby table in my office, by laying a hollow core door across a pair of two drawer file cabinets. Hobbies moved on to another bench in the shop, but the door has held up well as the top of my desk. Otherwise, check out MDF or plywood as SPS suggested, but my preference would probably be 3/4" plywood with a sheet of masonite on top.
Old 05-23-2013, 03:22 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 834
Butcher Block.......
ddawg16 is online now   Reply With Quote
Old 05-23-2013, 06:40 PM   #5
Rewards Points: 81
melamine
one cut is offline   Reply With Quote
Workbench light... switch chained from nearby outlet Koellert Electrical 3 08-21-2012 05:15 PM
Building a workbench. Need plans nikeman Carpentry 20 07-14-2012 04:14 PM
Drop leaf workbench. Imessano Carpentry 10 03-27-2012 05:42 PM
New House, new project: Workbench! Rono8582 Project Showcase 14 02-03-2012 01:05 PM
Need Help designing and building a workbench cnda17 Carpentry 2 12-19-2010 09:48 AM
