Woodworking Multi-apparatus - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-17-2005, 02:34 PM   #1
Woodworking multi-apparatus
Years ago, I remember an infomercial (before they were the norm - late 70's/early 80's?) for an all in one woodworking apparatus. Can't remember all the things it did, but I do remember that it was a lathe, and a drill press, and maybe a table saw. Anyone else remember it? I wanted to buy one when I was a kid, but then life took over. Life's slowing down, and I'm hoping to re-kindle that yearning for woodworking and actually build some stuff.
Anyway, does that apparatus still exist, and can anyone tell me where to find it? Anyone have one that can tell me if it's worth it?
sherlock is offline   Reply With Quote
Old 10-17-2005, 04:57 PM   #2
Contractor
I believe that you are thinking of the Shopsmith. http://www.shopsmith.com/
I have never owned one but most people seem to be happy with them.
Teetorbilt is offline   Reply With Quote
Old 10-17-2005, 08:37 PM   #3
Remodeler
MinConst's Avatar
sherlock,
I too had the dream of owning a Shop Smith MarkV when I was a younger man. My Dad said it was a waste. So life went on. Later I bought my dream machine from an friend that took care of it like a baby. I used the machine maybe 3 or 4 times. I put it up for sale and 2 years later it sold. I only lost a couple hundred bucks so it wasn't all that bed. My Dad was right, he usually was. I must add that I have other equipment that does the separate jobs. So it wasn't the tool of choice for me. It is a quality machine mind you. And does what it says. But the change ups take some getting use to. The table saw is not the best. This being the most used of the tools for most.
If you have the room for separate machines you would be better off with a decent TS, Drill press and lathe, if you use them.
One mans opinion.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
The Following User Says Thank You to MinConst For This Useful Post:
jaydevries (03-25-2013)
Old 10-18-2005, 10:11 AM   #4
Thanks for the advice. I'll keep my eye on ebay for a used one, and we'll see.
Old 10-19-2005, 10:34 PM   #5
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
That's the key is the space thing. From what I've seen, they are nice machines but when I'm in the shop, I run from table saw to miter box to drill press to sander to tables saw etc... I've watched that machine being changed and I don't think I'd have the patience for it (or get a lot of work done!) Now, if you had very little room and planned all your pieces so that you did all of the same job before changing, I'm sure it's a good solution.
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 10-29-2005, 07:27 AM   #6
I have a Shopsmith. I also have another tablesaw and a 12" compound miter saw. I use the Shopsmith quite often as an extra saw when I have a lot of things going on. I wouldn't want it to be my only saw, but it is good for what it is good for. It is a good drill press. I have never used it as a lathe. I do use the disc sander on occasion. The casters are horrible, so don't count on moving it around as easily as a bicycle. You can get any of the accesories you'd ever want on Ebay. You will want the 5/8" arbor for the saw blades, so you can use everyone elses saw blades rather than the 1" 1/8" bored sawblades Shopsmith sells. There selection of grinds on their blades lacks the variety you will need for materials available today.
kesac is offline   Reply With Quote
Old 03-25-2013, 07:14 PM   #7
Shopsmith
I have had a shopsmith mark 5 for a number of years and just recently purchased a model 510. Has anyone tried to take the alumnium extrusion from a model 520 and put on the fence of a 510. Larry
lalkie is offline   Reply With Quote
Old 03-25-2013, 07:36 PM   #8
Roofmaster
Rewards Points: 2,210
I agree completely with having separates. Woodworking requires going from one station to the next performing different tasks time and again. Constantly having to change a tool back and forth would drive me nuts. Machines like this usually end up gathering dust, not sawdust.
Old 03-26-2013, 08:27 AM   #9
My dad has a small shop and he is retired, so time is his own.
He has one and he seems to like it.
I have a feeling, like it or not, I will inherit it one day.
I'll put it to some use doing something.
oldhouseguy is offline   Reply With Quote
Old 03-26-2013, 09:34 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Ya know.....it's hard to beat a good large table saw, radial arm saw and compound miter saw along with sanders, drill press, about 5 hand drills, biscuit cutter and about 500 wood clamps....
Typical sequence for me....rip a bunch of 1.5" width strips of hardwood with the table saw...cut to length with the miter saw...use 2 different drills to drill pocket holes and run the screws.....clamps to hold....45 min's later...one face frame.....repeat as necessary...
Coppa Woodworking - Arch top doors BigJimmy Carpentry 8 06-22-2009 02:38 PM
I am looking for a multi tool ultrahunt Tools 4 11-20-2006 09:27 PM
my new woodworking videos thewoodwhisperer General DIY Discussions 6 11-01-2006 05:46 PM
