Wooden Step - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 07:12 PM   #1
wooden step
one of my steps is cracked in the middle;how do i repair that step
campbell is offline   Reply With Quote
Old 06-19-2012, 07:23 PM   #2
Rewards Points: 14,278
Post a picture.
In most cases you just remove and replace it.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (06-19-2012), PaliBob (06-20-2012)
Old 06-21-2012, 09:14 PM   #3
Rewards Points: 150
A photo will help with providing proper direction. But I'll provide general direction that may or may not help. Usually when I have removed treads I make a few cuts with a circular saw being careful that the blade depth is set to exactly the thickness of the tread, then with a wood chiesel that I keep for this type of situation I start splitting pieces of the tread out, finishing up carefully with a reciprocating saw. The riser is likely screwed or nailed into the back of the tread, the sides of the tread set into the stringer. Once the old tread is out you can determine the length to cut the new tread and also, if necessary, to rip the new tread, and best way to install it. Be sure to secure the new tread well or you will have a squeak every time someone steps on it. post the photo if you can and good luck.
TheCamper is offline   Reply With Quote
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
broken wooden step mountaintony Carpentry 7 09-09-2010 01:45 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
