Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-30-2008, 12:57 PM   #1
Wooden Post Sign Holder:
I'd like to build a simple, sturdy wooden post sign holder (has an "arm" coming out, the sign hangs from it??). For a "Home For Sale" sign.
Can anyone give me a plan, or walk me through it?
Also, how would I temporarily anchor this to the ground in a sturdy manner without permanently defacing the lawn?
minneapolis1 is offline   Reply With Quote
Old 11-30-2008, 08:22 PM   #2
Moderator
Termite's Avatar
Use 4x4 or 6x6 material. The best way to join the vertica to the horizontal is to use a half-lap joint. Do a search online for half lap joints and it will be pretty self explanatory. You can do it with a circular saw by making a bunch of saw kerfs and removing the material, then cleaning up with a chisel. Exterior wood glue and a few screws and you're good to go.
Set the post in the ground and compact the soil around the post very tightly. Add a little concrete if you want it more permanent.
wooden basement post rotten on bottom truckinkat Building & Construction 1 09-29-2008 06:35 AM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
How To: Post Nathan Site Help and Suggestions 0 07-04-2008 04:08 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 08:55 AM
