Wood Working - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 01:42 PM   #1
wood working
How do you measure angles to cut when you are making projects? example: I need to cut a 10degree angle off both ends of a 3"x5". I am a rookie trying to learn how to make things. Thanks
uncle b is offline   Reply With Quote
Old 02-17-2009, 01:56 PM   #2
Remodeling Contractor
Use a protractor. Also a triangular speed square would give these angles. What is a 3 X 5? What are you making? Maybe making a full size template out of paper would be a good start. Cheaper to re-cut and replace paper than the rare 3X5
Old 02-17-2009, 02:06 PM   #3
RippySkippy's Avatar
The paper template is a great idea...if you have many angles to cut, you might want to look at an angle finder. I have one similar to the one pictured...and it works ok, it has a protractor built in so you align the edges and read the gauge.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-17-2009, 02:43 PM   #4
Mr. Mariani, I am trying to make the lift up coffee table for my daughter and her husband as a wedding gift. It is located in Quick-and-Easy Woodworking Projects magazine page 28-32. You can find it on meiselwoodhobby.com. The problem I am having is with the part TABLE CLEAT G. Thanks for your help. I was incorrect on the measurement I gave you. It is a 1x4 3" wide x 11 1/2" long.
Old 02-17-2009, 03:48 PM   #5
This site is only to buy plans, so that does not tell us much. Is this angle you are working on along the flat side of the board or an angled edge? What tools do you have? Router? Table Saw? Scroll Saw? Jig Saw?
Old 02-17-2009, 05:27 PM   #6
The angle is on two of the four corners. I have all the tools you asked about.
Old 02-17-2009, 06:17 PM   #7
that is good, so do you have a protractor or even a speed square. These will mark out the angles. You could also use the miter guide on your table saw. Or easier yet is if you have a chop saw.
Old 02-20-2009, 10:02 AM   #8
Mr. Mariani, thanks for the help the other day on how to cut angles. I was dumb enough to not think about using my miter saw! I got that problem solved, now I have another problem. How do you round off the corners of the piece of wood when instructions says " R 5/8" for all four corners? Once again, thanks for your help.
Old 02-20-2009, 11:36 AM   #9
Old School
Willie T's Avatar
Lightly draw a pencil line parallel with both edges of the corner. Both lines 5/8" in from the edge. Where the lines cross is the center point of your 5/8" radius. Use a kid's school compass to scribe your corner from that point.
Or you can find a bottle top or a washer that is 1-1/4" across. (2 x 5/8") Fit it to the corner so that it is evenly touching both edges at its widest curve. Then just draw a line around the corner.
Willie T
Old 02-20-2009, 03:07 PM   #10
now do what was just posted on a piece of 1/4 masonite. Make a template of this curve. Now mark you project and cut outside the line at least 1/16" with your jigsaw. Now clamp the template to your pencil mark on the project piece and use your router with a pattern bit to make a perfect 5/8" radius.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
