Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-13-2011, 01:21 PM   #1
Wood Veneers
I have a teak coffee table with badly worn top. Rather than sand and stain I'd like to apply a very thin teak veneer. What's the best type and how is it glued down ? Will veneers fade if exposed to UV over a long period ?
cankiwi6 is offline   Reply With Quote
Old 11-13-2011, 02:11 PM   #2
Super Moderator
Wood Veneers
In a nutshell---It will be far easier to sand and refinish the original top---and cheaper--
To prepare the top for a veneer---sand perfectly smooth--seal with a thin wash coat of shellac
coat with hide glue and insert top into vacuum press---
Some backed veneers work with contact cement ---
Check out the Woodworking Talk web site ---link at the bottom of the page.
Old 11-13-2011, 09:17 PM   #3
sdsester's Avatar
Wood Veneers
I would sand it also. You will have to stop the veneer at the routered edges somehow and it will likely de-laminate the first time you nick it.
If it is badly or deeply gouged, you may have to take the top off and run it through a planer before sanding.
sdsester is offline   Reply With Quote
Old 11-13-2011, 10:19 PM   #4
Wood Veneers
There are a few considerations in sanding a top. You don't know how thick the wood is. Many tops have just a veneer before you get to the core. The newer the table, the thinner the veneer.
When you say the top is worn, what do you mean?
Photos might help.
Ron
B. Franklin 1759
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
