-   -   Wood Veneers (http://www.diychatroom.com/f14/wood-veneers-123318/)
cankiwi6 11-13-2011 01:21 PM
Wood Veneers
I have a teak coffee table with badly worn top. Rather than sand and stain I'd like to apply a very thin teak veneer. What's the best type and how is it glued down ? Will veneers fade if exposed to UV over a long period ?
oh'mike 11-13-2011 02:11 PM
In a nutshell---It will be far easier to sand and refinish the original top---and cheaper--
To prepare the top for a veneer---sand perfectly smooth--seal with a thin wash coat of shellac
coat with hide glue and insert top into vacuum press---
Some backed veneers work with contact cement ---
Check out the Woodworking Talk web site ---link at the bottom of the page.
sdsester 11-13-2011 09:17 PM
I would sand it also. You will have to stop the veneer at the routered edges somehow and it will likely de-laminate the first time you nick it.
If it is badly or deeply gouged, you may have to take the top off and run it through a planer before sanding.
Ron6519 11-13-2011 10:19 PM
There are a few considerations in sanding a top. You don't know how thick the wood is. Many tops have just a veneer before you get to the core. The newer the table, the thinner the veneer.
When you say the top is worn, what do you mean?
Photos might help.
